Telepost Adjustment - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-01-2016, 03:55 PM   #1
Rewards Points: 4
Telepost adjustment
Hey guys,
I've seen somewhere that telepost adjust has seasons or particular times of the year where you should not touch them. I have two that need adjustment.... Maybe half an inch to three quarters. We've had a rocky winter... Plus 5 to minus 30 degree Celsius within two days so wondering if i should wait until a specific time to adjust.
Thanks guys
j0nathan is offline   Reply With Quote
Old 03-01-2016, 05:13 PM   #2
Rewards Points: 18,118
Guessing you mean a lally column.
With the proper footing there should never be a need to adjust them.
If someone just set them on top of the slab with no footing there always going to be an issue.
47_47 (03-02-2016)
Old 03-02-2016, 12:34 PM   #3
Rewards Points: 4
Anybody?
Old 03-02-2016, 12:46 PM   #4
Civil Engineer
Rewards Points: 5,246
Your post is vague and makes it difficult to respond to. First off, a telepost is not a well defined term, so I am not clear what you have. I also cannot tell why you think the posts need to be adjusted. Not all posts are adjustable, not all posts are intended for permanent installation, and sometimes the posts are installed in such a way as to make adjustment impossible. If you post some pictures, and describe exactly what it is you are trying to achieve, and why you think you need to do it, you may get a more on point response.
Old 03-02-2016, 07:46 PM   #5
Rewards Points: 4
Ok. Here we are. Look closely at the top of the post. To the right, the previous homeowner made a wall directly under the rimjoist. Almost directly on top of the post is my kitchen and there is a noticeable bump. I know i will have to move the wall to let the rimjoist get down half an inch to an inch.
How would you guys go about fixing this bump. We're not talking 3 inches here either...
Old 03-02-2016, 08:09 PM   #6
Somethings really wrong with that whole set up.
Back that srew off and see if the beam drops enough to level the floor.
The support to hold that beam up should have been inside the wall on the right all the way from the bottom of the beam to the bottom plate with 4, 2 X 4's.
Interesting wiring job.
Old 03-02-2016, 11:20 PM   #7
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 844
That's the kind of post that I tell my clients to replace.
Aggie67 is offline   Reply With Quote
Telepost question Jimmyjim Building & Construction 4 01-12-2016 12:50 PM
Riello 40 Series, Air Adjustment Plate RCrosby257 HVAC 1 06-22-2015 05:31 AM
Need adjustment screw for adjustable threshold rvmeush Windows and Doors 1 11-20-2013 06:54 PM
Moving Telepost k_evjen Building & Construction 13 10-04-2012 11:04 AM
Tighten Garage Door Chain - No Trolly Adjustment kurdtkobain00 General DIY Discussions 1 10-11-2011 01:23 PM
