Tecumseh Electrical Start Conversion - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-20-2017, 01:06 PM   #1
Mike1148's Avatar
Rewards Points: 2
Question
I need info on Electrical start conversion - I have a 10HP Tecumseh on a Coleman Powermate contractor 5000W Gen, PLO525208 Ser 67070612, cast iron sleeve, looks like steel flywheel with no gear (light thrust) "looking in starter block off plate". I'd like to convert to electrical 12V start. No need for alt, connecting to the existing battery bank. Can I add a ring gear to this flywheel and install starter to the crankcase? existing tapered holes.
Mike1148 is offline   Reply With Quote
Old 04-21-2017, 10:23 AM   #2
Rewards Points: 462
Re: Tecumseh Electrical Start Conversion
I converted a Briggs 10 HP engine to electric start. I did this by going to a Briggs repair shop - authorized factory repair. And I took along the model number of the engine, and any other numbers on the engine/engine block.
Then the parts guy there was able to order the parts I needed. A geared flywheel, starter, screws was all as I recall. I added my own wiring, switch and battery. (I did not get a recharging alternator either.)
Justin_99 is offline   Reply With Quote
Is it compulsory to have a license to start an electrical repair service? Luzziemariam General DIY Discussions 6 12-30-2014 08:58 AM
help with moving a electrical outlet oscarnav Electrical 21 11-17-2013 07:32 AM
Running Electrical into an Insulated Room Samwise2013 Electrical 5 06-15-2013 11:12 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
