Swing Set Idea... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-05-2015, 09:01 PM   #1
Swing Set idea...
I am looking to build this swing set in the picture below. I plan on using 4x6x12 pressure treated for the post and also for the 12' beam. I plan to sink the posts 48" in the ground with cement. I also will have one swing, one toddler swing and a trapeze bar on the swing set. I feel it will be structurally sound due to the four posts. I am looking for input. Thanks!
csfurlong84 is offline   Reply With Quote
Old 03-05-2015, 10:04 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,416
How big are your toddlers???
Should be fine.
Old 03-05-2015, 10:07 PM   #3
I have a 4 year old and a 10 month old.
Old 03-05-2015, 10:08 PM   #4
Rewards Points: 42
Looks great! Nice plan. Appropriately hardened S-hooks and chain will help the swings stay up,
Larry K. is offline   Reply With Quote
Old 03-05-2015, 10:26 PM   #5
Great- thanks for the feedback... Yes I have purchased Swing-n-Slide extra duty hardware rated for up to 250lbs.
Old 03-05-2015, 10:57 PM   #6
JUSTA MEMBER
Rewards Points: 1,520
Does this hardware have any type of protective sleeve for the chain links?
I knew a youngster that liked to swing high and jump out of the swing, land and roll, until he left a finger behind accidently that is.
Them little fingers go into a link easily, and don't always pull out easy, especially when jumping out.
Just a safety feature that I try to add when building swing sets.
That swing looks plenty sturdy to me.
ED
de-nagorg is online now   Reply With Quote
The Following 2 Users Say Thank You to de-nagorg For This Useful Post:
gma2rjc (03-07-2015), Windows on Wash (03-06-2015)
Old 03-05-2015, 10:59 PM   #7
Ed
I purchased the swing-n-slide heavy duty swing that has the chain dipped in rubber
The Following User Says Thank You to csfurlong84 For This Useful Post:
de-nagorg (03-05-2015)
Old 03-05-2015, 11:22 PM   #8
Rewards Points: 468
your swing-n-slide link bring up a play telescope from a company named quill.com.
Jim F is offline   Reply With Quote
Old 03-05-2015, 11:41 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 17,676
This 'was' mine.....
The past weekend we removed that last part of it. About the time they reach 7-8, it will get no use.
That does not mean you don't build it....it just means you need to understand that it does not need to be permanent
ddawg16 is online now   Reply With Quote
Old 03-06-2015, 03:57 AM   #10
I am not sure why it made a link as I did not intend for there to be one.
Old 03-06-2015, 03:59 AM   #11
I agree that is why I want to keep it simple.
Old 03-06-2015, 09:39 PM   #12
Would it be correct to put pea gravel in the base of the 4' holes then place wet concrete around the post with a larger amount lower like a tear shape? Also how long does it take for all this concrete to dry to use the swing set?
Old 03-07-2015, 12:31 AM   #13
JUSTA MEMBER
Concrete sets in a few hours, but takes a week or more to properly cure. So your decision.
A bell shape sounds good and gravel allows some drainage to further prevent frost heave.
ED
Any thoughts on hanging a foot pedal on porch swing? tabatt07 General DIY Discussions 1 07-25-2012 05:54 PM
Tree Swing Help steveinCT General DIY Discussions 4 06-05-2012 08:34 PM
Strengthen porch swing joists jakate General DIY Discussions 2 02-22-2012 09:40 PM
Will this vertical-posts Swing set plan work? diy_in_md Building & Construction 14 10-15-2011 11:06 PM
an idea for siding a shed/studio forresth Building & Construction 0 09-08-2011 08:48 PM
