Sump Water Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 09:54 AM   #1
Jeanguypatateru's Avatar
Sump water issue
I have a sump in the basement and the pump runs every 15 to 30 seconds even when it's not raining. I suspected that the water being pumped out was somehow returning into the sump so I added food coloring and filled it with water. As I suspected the water coming into the sump became red in about 3 minutes. I assume this isn't normal. What do you suggest as a fix.
Your help is very appreciated.
Thanks.
Pierre.
Jeanguypatateru is offline   Reply With Quote
Old 03-30-2013, 09:57 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,416
Where is the sump discharging to?
It is obviously not far enough away from the foundation so it needs to be routed further away from the home.
Any pics of the exterior?
Old 03-30-2013, 09:59 AM   #3
ccarlisle's Avatar
Install a backflow check valve....Not expensive.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
The Following 2 Users Say Thank You to ccarlisle For This Useful Post:
Dave Sal (03-30-2013), ToolSeeker (03-30-2013)
Old 03-30-2013, 10:12 AM   #4
Rewards Points: 6,236
I totally agree^^^^^ put the check valve on the pump right where the water comes out it is a one way valve so the water in the hose can't come back in when the pump shuts off.
Old 03-30-2013, 11:08 AM   #5
Is the water coming back from the discharge pipe or back from the sump?
Should have a backflow preventer on it as a standard so +1 to the advice above. If it is running ever 30 seconds though, it sounds like it is just dumping it against the foundation and circulating the water.
Old 03-30-2013, 07:11 PM   #6
It's coming from the sump. Not the discharge pipe. I think it may be discharging too close to the house.
Looks like I have a lot of work ahead.
House is just a year old.
Old 03-30-2013, 07:21 PM   #7
Rewards Points: 18,376
Ok, so is there a check valve on the line just above the pump or not?
No way is the water not discharging far enough away from the house and running back into the sump in that short a time.
No check valve and it's going to be short cycling?
Should look like one of these.
http://www.bing.com/shopping/search?...alve&FORM=HURE
Old 03-31-2013, 07:54 AM   #8
Or it may have a check valve and it is stuck open.
Old 03-31-2013, 10:54 PM   #9
There is a check valve on the discharge line. There are two pipes that dump into the sump. This is where the red water was coming back in from. Which is why I believe it's not draining far away from the house.
I'm pretty sure the check valve works because when the pump stops, no water runs back in from it.
Old 04-01-2013, 09:43 AM   #10
Concrete & Masonry
Rewards Points: 462
Install at least 10' of solid pipe (3-4" pvc, 3" abs, etc..) onto the end of the current pvc discharge outside, and direct to an area that will drain as far away from the house as possible..............
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Windows on Wash (04-01-2013)
My hot water recirculation system is a disaster Michael Neill Plumbing 29 08-30-2019 07:15 PM
Sump pump is pushing water up into the bath tub. Eh? roasted Plumbing 29 03-12-2017 08:59 PM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
