Subpanel Grounding Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-02-2017, 02:48 PM   #1
Rewards Points: 4
subpanel grounding question
I seem to get a little confused with subpanels and grounding.
There is a 200 amp breaker at the meter. The house will be about 100' away from there. The panel in the home, I guess will act as a subpanel. So my question comes with the grounding of the subpanel in the house.
Will I run 4 wires from the main? I plan to use a ufer ground at the house. Is this necessary if I run a ground back to the main? If there is an option between the two, which is better? I understand the grounds and neutrals must not be bonded at the sub, but if I don't run a ground wire back to the main, can I treat the panel at the house as a main, and bond the neutrals and grounds, given that I am using a ufer ground at the house.
I don't really have a preference but just looking for the recommended way of doing it. There are no inspections required in this area. Thanks guys!
carlhue is offline   Reply With Quote
Old 07-02-2017, 03:00 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,258
Re: subpanel grounding question
The main along with all the sub panels will be grounded separately. No need to run a separate bare ground between the two. The 4th wire in your cable will handle that. Local ordinances may require you to have two grounding rods connected from the grounding buss in the main panel to each with a continuous conductor. As far as your UFER, they may only require one additional ground rod, attached to the sub panel in a like manner.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
carlhue (07-02-2017)
Old 07-02-2017, 03:09 PM   #3
Rewards Points: 4
Thanks, that makes sense. I guess I wasn't sure if it was better to not run the 4th wire and keep the grounds separate- I don't really know why I wondered that, just a thought I had.
Old 07-02-2017, 03:54 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,516
You must run a four wire feed to the sub panel and keep the neutral and ground separate.
The Following User Says Thank You to joed For This Useful Post:
question about grounding my old main fuse panel cmarcus3031 Electrical 13 11-19-2014 03:16 PM
Grounding Question - Standard device/switch kbucci Electrical 11 10-29-2014 05:13 PM
Question on grounding main lug service rizzoa13 Electrical 38 06-22-2012 04:25 PM
yet another 3 wire range hookup question - grounding receptacle plate/box? rkg Electrical 7 04-03-2012 02:02 AM
Grounding electrode at subpanel Randell Tarin Electrical 18 02-01-2008 10:05 PM
