Thread Tools | Display Modes |
#1 |
Rewards Points: 2,446
![]() Stripping paint off threads
I have hurricane panels over my windows. There tracks are mounted on the concrete walls with a threaded connection every six inches or so, the panels have circular holes at the bottom, the panel holes are lined up with the threaded connections then secured with wing nuts.
![]() When I had the house painted several years ago the painters put paint on these threads. So now the wing nuts won't go on smooth, some of them I need a plier to thread the wing nut on. I know I can probably clean the threads up with a metal wire brush...but I have like 20 windows so over 200 of these threads at the bottom, and another 200+ on top. I am looking for some quicker more efficient way to do this. I am thinking, if I can put together something with a matching female thread, that I can fit into my cordless drill or impact driver, I can just drive that onto the male threads and strip the paint off, then back out and move to the next, and should only take a few seconds to clean each thread. Thoughts? A bit holder, with a hex bolt into the bit holder, then the hex bolt into a long coupling nut? Glue together? |
Sponsored Links | |||
Advertisement |
#2 |
Remodel and New Build GC
Rewards Points: 298
![]() Re: Stripping paint off threads
A wire wheel on your drill.....?????
Or a thread chasing die for any difficult ones.... Msradell likes this.
Never stop learning (xcep fer speling en typeing) ![]() |
Advertisement |
#3 |
Super Moderator
![]() Join Date: Mar 2005
Rewards Points: 29,540
second the wire wheel.
Advertisement |
#4 |
Rewards Points: 2,612
Using a 3 corner (triangular) 6" slim taper file, file a groove or 2 or 3 inside a hex nut to thread depth then you can use it and your cordless drill to chase the threads.
That is, if the drill chuck will accept a nut the size you need. For that many I would modify the nut until it did chuck up if it were too large. |
#5 |
Rewards Points: 6,098
Purchase a 1/2" to 1/4" wrot copper coupling. File a couple slots in the 1/2" end to fit over the wings of wing nuts. Solder a short piece of 1/4" copper in the 1/4" end.
Chuck that in your drill. Go slow. If 1/2" is to big, use 3/8. Last edited by hkstroud; 10-16-2016 at 01:50 PM. |
#6 |
Rewards Points: 18,118
Trying to chase a bolt with a nut is a sure way to end up with crossed threads.
http://www.homedepot.com/p/POMA-Stee...011B/202385848 A wire wheel like this will rip the paint off in seconds. http://www.harborfreight.com/4-in-wi...ank-60318.html
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#7 |
Rewards Points: 1,830
For that many studs buy yourself a rethreading die which is "a matching female thread". Measure the diameter of the stud, or bring a nut with you to where you can get one. Home Depot sells them online but doesn't stock many of them in stores. Look for a machine shop supply store in your city.
Power- likes this.
#8 | |
Rewards Points: 8,488
![]() Re: Stripping paint off threadsQuote:
But a standard threading die would be just a few dollars and readily available anywhere. Just that a standard handle would likely hit the other studs --- you would have to make something up. I would just do it by hand --- standing on a ladder running a drill with a thread cutter on the end sounds like a good way to bugger up threads. Wire wheel going to be difficult to brush just the threads without scraping up the paint an adjacent surfaces. |
#9 |
Rewards Points: 262
Wire wheel would be the sure bet but don't use a grinder for it, only drill. I would start with brass wires if you can find it. Aggressive wires could damage the bolts. Also wear a goggle. I was grinding a paint off a rail and broken off wires were like arrows.
Copper fitting cleaning wire brush from the plumbing works well. I buy the twisted wire handle and cut off the handle for chucking into a drill. Make a slotted sheetmetal cover so you don't scratch the brackets and you probably don't have to clean it 100%. |
#10 |
Rewards Points: 322
IMO a die would be quickest and cleanest way
#11 |
Rewards Points: 386
And after you get done stripping, put a piece of clear vinyl tubing over the threads to prevent gunk build up. Keeps the threads nice and clean and makes the installation go a lot quicker when the storm is on the way. I also hit them with a little lubricant before I slide on the tubing
#12 | |
Rewards Points: 708
Battery powered Dremel with a wire wheel
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Ready to paint the porch! Oil or latex? | Leah Frances | Painting | 10 | 08-24-2015 03:59 PM |
Lead Paint Follow-Up | RoughDraft | Painting | 24 | 06-18-2013 08:31 PM |
Best paint remover for stripping latex? | DanielP | Painting | 3 | 04-30-2008 08:21 AM |
