Stacked Stone (MSI Silver Travertine) Installation Gaps - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-28-2017, 10:09 AM   #1
Rewards Points: 30
Stacked Stone (MSI Silver Travertine) installation gaps
I had stacked stone installed as part of my new finished basement and have notices several large gaps in it. Would this be likely due to improper install or use of bad pieces?
I'm trying to determine if I should
1) leave it as is.
2) attempt to grout the gaps to fill the space or
3) demand they be ripped out one reinstalled.
I don't see how you could fix the offending ones without ripping them all out so I am looking at ways to fill these voids. Any opinions or suggestions would be much appreciated!
Tearing down is not my preferred option as I dont trust they have the ability to install them correctly.
Thanks!
Stacked Stone (MSI Silver Travertine) installation gaps-20170428_100051_1493388065354.jpg
longtee81 is offline   Reply With Quote
Old 04-28-2017, 10:36 AM   #2
Rewards Points: 30
Here is a better zoomed in picture.
Stacked Stone (MSI Silver Travertine) installation gaps-20170428_101053_1493390183854.jpg
Old 04-28-2017, 10:38 AM   #3
Rewards Points: 30
Attached...
Stacked Stone (MSI Silver Travertine) installation gaps-screenshot_20170428-103753_1493390286417.jpg
Old 04-28-2017, 10:57 AM   #4
Civil Engineer
Rewards Points: 5,246
Re: Stacked Stone (MSI Silver Travertine) installation gaps
Is that a non-structural veneer wall? What did your contract specify as to the appearance of the wall?
Old 04-28-2017, 11:45 AM   #5
Rewards Points: 30
I believe so. It is the backsplash over the wet bar. He also did my fireplace using the same material and that doesn't have any of these noticible gaps.
Old 04-28-2017, 02:09 PM   #6
Rewards Points: 30
My contract was very informal and did not specify details on how the stone would be installed, only that it would be installed and I would pay for the cost of materials.
Old 04-28-2017, 02:17 PM   #7
Civil Engineer
If your contractor lived up to the terms and conditions of the contract, I don't see why you think you have the right to ask him to reinstall the stone, simply because you do not like the appearance. In general, contractors are only required to follow the terms and conditions of the contract, unless there is something illegal going on (for example, you enter into a contract to install a new electrical system, and the contract specifies that the contractor will not pull a permit). If you don't like the appearance, I think the best you can do is to discuss your concerns with the contractor to see what they might be willing to do.
Old 04-28-2017, 02:34 PM   #8
Rewards Points: 30
Yes I agree. I'm not looking to have it reinstalled or pull the contract and get nasty. He has done a lot of sketchy things that I will not elaborate on, but he has also been willing to do some extra things that were not in the contract that I am very satisfied with.
I really want to fix it myself or leave it as is and was looking for opinions on what I should do and how bad this looked. I was surprised to see all of these gaps and they are permanently there.
Old 04-28-2017, 05:11 PM   #9
JUSTA MEMBER
Rewards Points: 414
Find a tube of colored caulk, carefully fill and gently wash any excess away with a damp sponge.
Magic :the gaps are filled and disguised to not be seen unless you say something to the viewer.
Get caulk the same color as the grout lines .
ED
de-nagorg is offline   Reply With Quote
Old 04-29-2017, 07:00 AM   #10
Rewards Points: 898
Doesn't look that bad in the picture. I was going to get that stuff for a fireplace, i thought it was idiot proof for my mason but I guess not.
BIG Johnson is offline   Reply With Quote
Old 04-29-2017, 09:44 AM   #11
Rewards Points: 2,815
Tough to get in there without making a mess. Caulk is pretty sticky. It might be impossible to clean up if you get it on the surface. If you go that way, consider pumping it through a flattened drinking straw to get it way in there. Maybe tape off both sides of the crack. Maybe use regular grout and pump it through a baby syringe. I'd definitely do some experimenting first.
mathmonger is offline   Reply With Quote
Old 04-30-2017, 02:56 PM   #12
Rewards Points: 30
Thanks for the suggestions and comments. I will experiment in some of the less visible locations and tape before I caulk.
Laminate floor is cupping and gaps. Installation issue? keysermtl Flooring 12 03-28-2013 06:24 AM
Buying an electrical outlet costing .99 cents vs. $3.00 Mikon8er Electrical 40 11-20-2011 12:01 PM
Gaps between sheets - new installation diykc Drywall & Plaster 4 12-27-2009 07:35 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
Travertine installation wrober Flooring 1 02-26-2008 03:25 PM
