Sloppy Trailer Tongue. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree18Likes
Old 07-20-2018, 07:30 AM   #1
Rewards Points: 898
Anyone know how to tighten up the clamping mechanisms on this type?
There’s a lot of slop when starting out and stopping you can really feel it. There’s no nut to tighten like on most hitches.
BIG Johnson is offline   Reply With Quote
Old 07-20-2018, 08:20 AM   #2
Rewards Points: 2,556
Re: Sloppy Trailer Tongue.
Have you tried a larger ball?
de-nagorg likes this.
Old 07-20-2018, 08:29 AM   #3
retired painter
Rewards Points: 824
Are you sure the hitch fits snugly in the receiver? I used to have jeep that the receiver was worn out and allowed a lot of play. The fix was to replace the receiver but I just shimmed it with sheet metal since I rarely pulled anything with that vehicle.
mark sr is online now   Reply With Quote
Old 07-20-2018, 08:37 AM   #4
Is it loose on the ball or is it loose in the brake mechanism?
daveb1 is offline   Reply With Quote
Old 07-20-2018, 08:39 AM   #5
Rewards Points: 898
Not mine, I’m asking for someone else. I don’t even know what size ball it takes. Maybe that’s the problem, he has too small a ball. I just assumed he had the proper match up.
Old 07-20-2018, 08:58 AM   #6
jproffer's Avatar
Rewards Points: 354
Oh man....my mind was com-PLETELY somewhere else with this.
My first thought was "well he!!, I don't care if she lives in a trailer"....
but I get it now
My first thought would be wrong size ball also.
How much play are we talking about? Say, in inches? 1/4? More? Hopefully not more or he has a real risk of it just popping completely off.
jproffer is offline   Reply With Quote
Old 07-20-2018, 08:59 AM   #7
Rewards Points: 22
Looks like the receiver has the multi choice sized balls, so it will be easy to find out if he is using the wrong size. Someone should probably check the receivers chassis mount bolts for the right torque.
dd57chevy likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 07-20-2018, 09:20 AM   #8
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,258
one of the two - or both.
worn receiver hole and pin or wrong size ball.
a closer look at the hitch also reveals some moving parts
that need to be looked into as well as all the connectors.
Bondo, daveb1 and Gregsoldtruck79 like this.
Johnny_inFL is offline   Reply With Quote
The Following 2 Users Say Thank You to Johnny_inFL For This Useful Post:
BIG Johnson (07-20-2018), jproffer (07-20-2018)
Old 07-20-2018, 09:50 AM   #9
I've yet to see a trailer tongue coupler that didn't have the ball size permanently stamped into it. But I don't get around much.
lenaitch and de-nagorg like this.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 07-20-2018, 11:59 AM   #10
Rewards Points: 898
but I get it now
Not sure, it was pretty sloppy riding in the car. I didn’t really get a chance to look at it, I barely had time to snap that picture. Owner said it was like that since new and was told it was supposed to do that because the jerking forwards engaged the trailer brakes. I told him it shouldn’t need to be jerky, just the force caused by braking should be sufficient.
Old 07-20-2018, 12:33 PM   #11
So now we are informed the trailer has a hydraulic brake system. That changes things dramatically in the diagnosis department. I'm gonna quit guessing now.
Old 07-20-2018, 12:38 PM   #12
BJ - can you post a photo of the whole trailer ??
and as Senior said: the ball size is almost
always stamped on the top of the coupler. in this case, the Ball Size
and Weight Class appears to be on the paper tag.
next thing to do is ensure the two are matched correctly.
I have never seen a coupler like that - so it is new to me.
Old 07-20-2018, 12:47 PM   #13
jproffer's Avatar
Rewards Points: 354
I haven't seen that style coupler either, but if it's like most...I would assume that lever in the front should be down when in use?....I also only assume that when he's towing it, it is, in fact, down and locked to the ball?
Good catch on the moving parts also Johnny. Didn't see those the first time around. If that pin is sliding forward/backward the entire length of that slot, I can imagine it would make quite a rattle. And I don't know what would stop it...a retaining ring like that wont "tighten down" to even slow down any sliding that would happen.
Old 07-20-2018, 01:52 PM   #14
jproffer's Avatar
Rewards Points: 354
Just saw another interesting "note" on the hitch. "Check Fluid Level". What fluid?? Where?
Ok, so maybe (????...anyone?) brake fluid?...maybe that slide looking thing activates the brakes after-all?
(I admit, I had kind of dismissed the comment about having to slam like that to activate the brakes...I'm so ashamed )
So with no fluid to "dampen" the slide effect, maybe it would slam ahead like described.
I'm way out on a limb...I really have no idea if what I just said is even in the ballpark.
Old 07-20-2018, 02:26 PM   #15
jproffer's Avatar
Rewards Points: 354
and another:
here's some more info regarding the emergency brake and brake system amination, but it shows the mechanism (some of it)....might be helpful to see...??
Like I said...I, personally, am out on a limb...I'm grasping for straws
The Following User Says Thank You to jproffer For This Useful Post:
sloppy tongue groove joints with table saw pman626 Carpentry 12 02-06-2018 09:55 PM
my first tongue & groove cabinet door. Joints are tight during dry fit, but sloppy pman6 Carpentry 13 06-12-2015 08:59 AM
Trailer wiring.. mchipser Automotive Repairs 13 05-20-2015 10:45 PM
Converting Utility Trailer -> Boat Trailer trekkiejt Automotive Repairs 5 07-17-2012 10:53 AM
Do we have any trailer gurus in the house? Mr Chips Automotive Repairs 16 08-11-2011 09:29 PM
