Showers Caulking As Maintenance Item? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-22-2013, 11:19 AM   #1
Rewards Points: 93
Showers caulking as maintenance item?
Just want to get your opinion about the showers caulking,
Do you cut them out and re-caulk every so often as maintenance item OR re-caulk when have issue/crack/leak?
Thanks in advance.
quincy is offline   Reply With Quote
Old 11-22-2013, 11:40 AM   #2
bbo
when have issue.
inspection should be a regular item.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
quincy (11-22-2013)
Old 11-26-2013, 12:26 PM   #3
Rewards Points: 154
If it is clean and still adhering, no need to do anything with it. If it is pulling up or mold is growing under it it's time to pull it up, clean the area, and re-apply. Generally I find if it is good stuff applied properly you should only have to mess with it every couple years or so.
eharri3 is offline   Reply With Quote
The Following 2 Users Say Thank You to eharri3 For This Useful Post:
quincy (11-27-2013), wkearney99 (11-28-2013)
Old 11-28-2013, 08:30 AM   #4
Rewards Points: 230
I replace the silicone caulking on my acrylic Jacuzzi tub/acrylic shower tub
enclosure each year. The caulk usually starts separating after a year or so and it starts discoloring also. When you do this every year you get pretty good at it.
Larryh86GT is offline   Reply With Quote
The Following User Says Thank You to Larryh86GT For This Useful Post:
quincy (11-28-2013)
Old 11-28-2013, 10:24 AM   #5
Rewards Points: 93
So, you are doing it as a maintenance item then.
Old 11-28-2013, 02:29 PM   #6
Rewards Points: 230
Both I guess. It needs recaulking with the separation and the recaulking does freshen it up.
Old 11-29-2013, 01:31 PM   #7
Rewards Points: 93
Larry, it looks so clean and neat.
Old 11-29-2013, 05:05 PM   #8
Rewards Points: 230
Thanks. Over the years I've tried various latex caulks and silicone caulks for this. The one caulk that has worked the best and shows the brightest white is the GE 100% Silicone I. I pull the old silicone off, wipe the area down with Isopropyl alcohol, apply the silicone as light as possible, then smooth it out with a wet finger.
Exterior Window Caulking Amitabh Windows and Doors 7 11-13-2012 11:37 AM
Bathroom floor/tub and caulking soulstar General DIY Discussions 5 11-10-2011 11:49 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 06:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 06:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
