Shower Door Sealing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jeffmattero76
Old 03-02-2017, 11:03 AM   #1
Rewards Points: 32
shower door sealing
Regarding the sealing of shower door frames to the marble sill at the bottom of the frame. I have a leak at this interface between the frame and the sill. Before I re-caulked, I noticed that only the outside of this interface is caulked; i.e. there is no caulk on the shower side of the frame. After looking at two other similar showers in my home, I found that none of them are caulked on the inside.
I'd appreciate feedback on my conclusion that this is common practice and is done so that water will not leak into the underside of the frame, be held there, and allow mold to grow, i.e. water that gets in there can drain back out.
jgtibbs66 is offline   Reply With Quote
Old 03-02-2017, 11:31 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,712
Re: shower door sealing
In my opinion, there should be caulk on both sides, but take special care to not caulk over the weep holes on the tracking.
Caulk the screw heads and you can individually removed them and back caulk before reinstalling.
If you are worried about water getting out, then something is wrong with the track. The only entrance point for waters where the track is penetrated is at the screws and those should be easy enough to seal.
The Following User Says Thank You to Windows on Wash For This Useful Post:
jgtibbs66 (03-02-2017)
Old 03-02-2017, 08:39 PM   #3
Rewards Points: 32
Thanks for the additional information.
Old 03-06-2017, 04:45 PM   #4
Rewards Points: 312
I found if the space between the track and the tile is too great, press some rubber stripping in there then caulk both sides. I used some screen door tubing (not sure what to call it) the rubber tube you press in the groove when repairing a screen door or window...
KPDMinc is offline   Reply With Quote
The Following User Says Thank You to KPDMinc For This Useful Post:
jgtibbs66 (03-07-2017)
Old 03-07-2017, 10:59 AM   #5
Rewards Points: 32
A useful tip...thanks.
Old 03-13-2017, 11:05 PM   #6
Rewards Points: 4
Do you have a photo of the shower available?
Sent from my SM-G930T using Tapatalk
tommyrhodes is offline   Reply With Quote
Old 03-14-2017, 02:22 PM   #7
Flannel Guy DIY
Flannel Guy DIY's Avatar
Rewards Points: 224
yes caulk on the inside as well. I remodeled my bathroom and I used clear caulk that was also more like a liquid nails type of product. Lasts longer. Wish I could remember the brand. If I do, I will post back.
For anyone who may stumble across this thread later just looking for a how to calking video... I am starting a thread on that. Wont post the video here out of courtesy unless jgtibbs66 allows me to.
Flannel Guy DIY is offline   Reply With Quote
The Following User Says Thank You to Flannel Guy DIY For This Useful Post:
jgtibbs66 (03-14-2017)
Old 03-14-2017, 11:43 PM   #8
Rewards Points: 32
By all means...please feel free to post your video.
Old 03-15-2017, 07:53 AM   #9
Flannel Guy DIY
Rewards Points: 224
ok here you go. I am also giving away one of these dripless caulking guns in the video
How To DIY Videos YOUTUBE - Giving away free tools to subscribers!
Old 03-16-2017, 04:30 PM   #10
Rewards Points: 18
It's called "screen spline"
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 03-16-2017, 04:44 PM   #11
Rewards Points: 18
Next time you apply caulk, cut the tube at a 45 degree angle and try pushing the caulk gun along the seam rather than pulling it. I read that tip years ago and thought the writer was crazy. Then I tried it. You will never go back to pulling it toward you again. The spout acts similar to your finger and smooths the caulk with little to no excess. It is amazing.
tommyrhodes likes this.
Old 03-16-2017, 09:44 PM   #12
Flannel Guy DIY
Rewards Points: 224
I heard about that 45 degree + pushing forward thing a few days ago...after I made the video. I am going to try it and may create a second video just about that if it works well for me.
Old 03-16-2017, 10:52 PM   #13
Post it up when you do it. I want to see it in action.
Old 03-16-2017, 11:02 PM   #14
Flannel Guy DIY
Rewards Points: 224
I will probably create a new thread on it
Old 03-17-2017, 07:31 AM   #15
Rewards Points: 18
I keep the opening in the relatively small. If there is a large gap to fill, i simply push the gun slower and/or go back over the gap a second time. I also move the gun far more rapidly than is shown in your video.
Let me know what you think.
Tags
shower door , shower door caulking , shower door leaks
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 06:38 AM
General Questions w/ Pics on 1st Time Shower Pan Build/Install amodoko Plumbing 10 06-10-2015 03:45 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 10:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
