Should I Be Concerned?!?! Pictures Attached - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 03:46 PM   #16
Definitely tear out the the fiberglass and trace the water source while it's wet...that's the best time to investigate water leaks, when the evidence is fresh. I would not recommend just adding additional layers of poly to cover up an issue behind the walls. That picture looks like a fair amount of water leaking...not just condesation. Tear out, investigate, repair the water leak source, and then go back to adding the vapor barrier.
capmizzou is offline   Reply With Quote
Old 02-06-2011, 06:19 PM   #17
Originally Posted by fungku View Post
Actually tyvek is a moisture barrier and an air barrier if sealed properly.
It lets vapour through.
Like Gore-tex. The rain stays out but you stay dry because it "breathes" (i.e. vapour permeable).
Agree. Tyvek is a one-way moisture barrier. It allows water vapor to pass through it, but not the liquid itself. This allows the water vapor that is created inside the house (like steam from a shower or cooking) to escape, but it does not allow rain to get into the woodwork. Nor does it allow a great deal of air to escape from inside the house.
NewEnglandYank is offline   Reply With Quote
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
6/4 AL for Attached Garage Sub Panel theatretch85 Electrical 3 04-28-2009 02:32 AM
Building Attached Carport MikeVila Building & Construction 4 01-12-2009 05:23 PM
Basement 2x2 furring strips, basement clutter, top plate not attached to floor joists touchsuhas Remodeling 5 12-26-2007 07:01 PM
How can I increase PSI in my boiler? (pics attached) drh HVAC 3 12-18-2007 06:26 PM
