Sheetrock - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-17-2015, 08:24 PM   #1
Rewards Points: 2
Sheetrock
If I am going to apply two or three coats of waterproofing similar to redguard then why does it matter what type of sheetrock I use on the shower walls?
miket1975 is offline   Reply With Quote
Old 02-17-2015, 08:51 PM   #2
Rewards Points: 18,382
No form of sheetrock is escapable in a wet area.
What's going on the walls? Enclosure, tile?
Talked to you building inspector and have a permit?
Old 02-17-2015, 09:42 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
I think it has to do with condensation and being mildew resistant where there are no tile and under the tile.
Robpo is offline   Reply With Quote
Old 02-18-2015, 12:04 AM   #4
Rewards Points: 5,010
Here's the 100 million dollar question.?
Can't wait to see the answer.
ron45 is offline   Reply With Quote
Old 02-18-2015, 07:29 AM   #5
Rewards Points: 540
No system guarantees water proof in a stick built house, using the materials we use. Example, Schuluter uses thinset. If tiles are installed using thinset, why does it fall off? Because thinset is porous and thinking thinset to water proof anything is illusion.
Using thinset, cement board, redguard, etc, slows down the damage or replaces the material that mold likes.
Build it the old way when labor and materials were cheap, such as inch thick mortar behind the wall tiles (not just the floor), no insulation so the insides can breathe, then lasting 100 years makes sense.
carpdad is offline   Reply With Quote
Replacing Sheetrock Window Trim with Wood - NEWB Alert - Please Help! Mark79 Remodeling 7 01-24-2012 12:37 PM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 08:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Using nail Gun on sheetrock jwshome Building & Construction 12 09-08-2009 10:16 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
