Shed Kit - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree18Likes
Old 03-08-2019, 12:04 PM   #1
Rewards Points: 24
Shed kit
Howdy y'all !
I am considering to buy:
https://www.bjs.com/product/shelter-...00000000873088
Any thoughts about "the good, the bad and the ugly" about that kit?
Also - any ideas how much it would cost to get composite walls for that frame?
JustA_dude is offline   Reply With Quote
Old 03-08-2019, 12:39 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,184
Re: Shed kit
Never used anything like that.
All I can say as someone who can cut miters etc. I would not use it. I seems to be made for someone who has zero experience cutting wood or building anything. I have no idea how strong or sturdy it would be.
The Following User Says Thank You to joed For This Useful Post:
JustA_dude (03-08-2019)
Old 03-08-2019, 01:01 PM   #3
retired framer
Rewards Points: 4,828
Re: Shed kit
So you know that kit is just 20 pieces of metal.
Do not use flat bottom gables with scissor trusses.
Old 03-08-2019, 01:07 PM   #4
retired framer
Re: Shed kit
You don't need the ones at the bottom of the studs.
https://www.amazon.com/Hopkins-90192.../dp/B000E3XNC0
Old 03-08-2019, 01:42 PM   #5
Rewards Points: 24
Re: Shed kit
Thanks for clarifications !!! I must've misread and thought that it does come with wood for framing
Old 03-08-2019, 01:49 PM   #6
retired framer
Re: Shed kit
That is not to say it is a bad deal and it would make it build much easier than learning all the math.
jproffer likes this.
Old 03-08-2019, 05:36 PM   #7
Super Moderator
joed's Avatar
Re: Shed kit
Wood to frame a shed like that is going to run you $400-$500.
Old 03-08-2019, 05:49 PM   #8
HenryMac's Avatar
Rewards Points: 1,002
Re: Shed kit
Looks like a fun project.
It is a bit misleading though. The text states:
Only straight, 90 degree cuts are required
No miters or complex measurements are needed
Yet in the photo you can clearly see that the wood members are not cut at 90 degrees. No big deal, but I just wonder what else is not as it appears?
That being said, for a guy with little to no experience, and working by himself or just one helper... those brackets would be super helpful.
We had one of those small sheds at a home we bought in the late 1990's. It was a great space.
Good luck, keep us in the loop.
SPS-1, schreibdave and Nealtw like this.
HenryMac is offline   Reply With Quote
Old 03-08-2019, 06:07 PM   #9
Rewards Points: 24
Re: Shed kit
i did see it... i just ignored it
as quite often happens - those that design and build aren't those that write manuals ...
HenryMac likes this.
Old 03-08-2019, 06:21 PM   #10
retired framer
Re: Shed kit
I think it would work with square cuts but the picture should have showed that.
Old 03-08-2019, 06:53 PM   #11
HenryMac's Avatar
Re: Shed kit
I think it would work with square cuts ...
I totally agree... but it would be loose as a goose.
My German heritage has taught me to always build Goodntight and Hellferstout.
dd57chevy likes this.
Old 03-08-2019, 06:56 PM   #12
retired framer
Re: Shed kit
And here I thought you were Dutch, wooden shoes, wooden head, wouldn't listen
dd57chevy and HenryMac like this.
Old 03-08-2019, 07:07 PM   #13
HenryMac's Avatar
Re: Shed kit
It makes for a very strong building. Ever used hurricane ties? The brackets hold the pieces parts in position. And since nails have a tendency to loosen over time, the brackets tend to minimize that.
Old 03-08-2019, 07:08 PM   #14
HenryMac's Avatar
Re: Shed kit
Opinions vary...
KaseyW, dd57chevy and Nealtw like this.
Old 03-08-2019, 07:30 PM   #15
Big Dog
Drachenfire's Avatar
Rewards Points: 4,308
Re: Shed kit
I suggest you just build a good old fashioned gable roof shed.
There are relatively simple to construct and plenty of videos online that show how to build one or you can get a kit starting at about $1200 for an 8'x8' model
In 2003 I built my 10'x12' shed from scratch.
If memory serves I paid about $1300 for the supplies including the gravel for the base, pier blocks and hardware. Accounting for inflation that would be about $1800-$1900 today.
It took me about 5-6 weekends to build.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
The Following User Says Thank You to Drachenfire For This Useful Post:
Tags
shed , shed construction , sheds
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 02:39 PM
[Canada Code] Sharing 240V and 120V appliance on same circuit in workshop shed? mdrejhon Electrical 37 11-13-2016 08:53 PM
shed repair discussion JKeefe Building & Construction 7 07-26-2014 08:22 AM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
