Service On Off Outdoor Switch For Well Pump - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-09-2019, 02:31 PM   #1
Service on off outdoor switch for Well pump
I wanted to attach an outdoor service switch next to my well water pump. Simple 220 Volt three wire from circuit board to the switch and onto the motor. Otherwise without it I have to walk back and forth inside the house circuit breaker box to outdoors just to work on it. Would 30 amp single throw switch work and do you think it should need fusing?
NeilF is offline   Reply With Quote
Old 07-09-2019, 02:45 PM   #2
Rewards Points: 680
Re: Service on off outdoor switch for Well pump
You need a 2-pole switch to disconnect both hot conductors. Amperage sized to the circuit.
LawnGuyLandSparky is offline   Reply With Quote
Old 07-09-2019, 03:07 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
Use a 60 amp AC pull out disconnect. Less than $10.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 07-09-2019, 03:53 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,500
No fusing needed. That should be already taken care of.
