Septic Tank Found Under Driveway - What Are My Options? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2015, 09:46 PM   #1
Rewards Points: 6
Septic tank found under driveway - what are my options?
Hi All - thanks for taking a look at this. I understand that a professional will handle this, but I wanted to know if anyone here has ever experienced this situation?
We are looking at a home, built in 1980 which has been renovated over time. It sits on 5 acres. Permits show that a driveway was poured in 1990. When attempting to find the septic tank so it can be inspected, 2 septic companies and a GC could not find it. They use standard probing. The Realtor hired a plumber who first wanted to try a snake method vs using the line locator. He used a Sectional machine and put the cable down the vent pipe on the roof. Turned it on and we went hunting. Turns out we heard the rattling under a particular part of the driveway slab, perhaps poured at a different time, as the expansion joints looked different than the original.
My assumption is that they will rip up the concrete, locate the septic, pump it, fill it with sand, get access to the drain line and hook up a new septic in another part of the yard and bring everything up to code. They are not sure where the leech / drain field is.
I am curious if "they" think they can save money and reuse this somehow and put a manhole cover over it. I don't think that is acceptable. I assume you should not be driving over a septic tank to begin with, and that a driveway over a system is not up to code.
Any stories to share?
Thanks all - have a great night
mtarallo is offline   Reply With Quote
Old 12-09-2015, 10:07 PM   #2
Rewards Points: 8,046
The final answer MUST come from your local code enforcement. Now that the can of worms have been uncovered they can't just hide it and go forward. A new septic design has to be done and then submitted to the town/city for approval. Whether they take action against the current owners is up to them, but the current owners will only be digging themselves in deeper if they make any modifications without following the proper steps.
Bud
Not an engineer just a contractor
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
mtarallo (12-11-2015)
Old 12-09-2015, 10:11 PM   #3
griz's Avatar
Rewards Points: 572
I see it all the time.
Put an inspection cover on it & call it good.
If it ain't broke don't fix it....
griz is offline   Reply With Quote
The Following 5 Users Say Thank You to griz For This Useful Post:
dd57chevy (12-11-2015), mtarallo (12-11-2015), ron45 (12-10-2015), roofermann (12-10-2015), Windows on Wash (12-10-2015)
Old 12-09-2015, 11:03 PM   #4
Msradell's Avatar
Rewards Points: 972
There's absolutely nothing wrong with having the septic tank under the driveway as long as the top of it is reinforced well enough to handle the weight. Actually, it's quite a good space as long as you have a nice access hole with a removable cover. Easier than having to dig up a space in your yard every time you want to look for the cover and have a tank pumped. It's done quite often in different areas of the country.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Old 12-10-2015, 06:27 AM   #5
Rewards Points: 3,130
I'm not sure I'd want my tank to be under a driveway. But in any case, that would not be allowed here. We are in part of the Chesapeake Bay watershed, and the rules for septic systems are quite strict, as we found out when we built our house about 6 years ago. Concrete tanks are not allowed; ours is some sort of plastc. And the access cover cannot be buried; it must remain above ground and accessible. We also had to designate a 1/4-acre portion of our property as "septic reserve." That's a location for another septic system if the first one ever fails. Nothing permanent can be built in that area. Essentially, you can't build a house on any lot that isn't at least 1 acre in size.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 12-10-2015, 06:56 AM   #6
Rewards Points: 1,414
Under most circumstances I would require it be fixed and brought up to code, or else estimate the cost of doing that and get it knocked off the price. But others are right--you really need to consult the local code authority, because YOU don't want to be in the position down the line of selling a house someone won't buy because the septic is under the driveway. Also, you note that this part is "perhaps poured at a different time," and the current owners didn't even *know* where the septic tank was, so keep in mind it may not have been pumped in more than a decade.
Which itself makes it likely the septic field has less life left in it than you would like.
This would make me concerned about whether other maintenance tasks had been neglected, and I would suggest getting a good contractor to look over the house and check other key systems. (Oil or gas tanks, radiators, roof leaks, signs of water leaks, really anything maintenance-related).
Of course, you might be willing to take on the costs and risk of fixing the septic if they lower the price enough. That's a bargaining decision you can make once you have more price information.
Tom738 is offline   Reply With Quote
The Following User Says Thank You to Tom738 For This Useful Post:
Old 12-10-2015, 07:03 AM   #7
Rewards Points: 3,508
What's the potable water source for the residence, municipal or well water. If a well, we must know where the leach field is also.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 12-10-2015, 07:21 AM   #8
craig11152's Avatar
Rewards Points: 1,220
I am no expert at all, indeed I know little to nothing about septic systems. But generically we all drive over city sewer systems that run under roads. It seems a septic tank is a similar concept. Granted the sewer system is designed to accommodate vehicles above and that may not be the case here. But the fact that its under a driveway doesn't seem like some inherent, cosmic flaw.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
Old 12-10-2015, 09:08 AM   #9
Well, as you yourself said, you do seem to know nothing about septic systems. If the tank is underneath a concrete driveway, the issue isn't vehicular traffic, it's access. Septic tanks need to be pumped out every few years, and if one is under a driveway, there's no way to do that without busting up some concrete, which could cause damage to the tank as well. And as I mentioned in my earlier post, in some places the access cover cannot be buried.
Old 12-10-2015, 09:36 AM   #10
craig11152's Avatar
There is no shortage of access to sewer lines under streets. I can see one out my front window 20 feet from my driveway.
Old 12-10-2015, 10:21 AM   #11
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 844
In NJ you can't pave or build over a septic tank or the leach field. NJAC 7:9A.
Aggie67 is offline   Reply With Quote
Old 12-10-2015, 10:37 AM   #12
Civil Engineer
Rewards Points: 5,246
I don't really understand the OPS situation. From the description, he is "looking at a house". To purchase presumably? If the OPS is thinking about purchasing the house, then of course he will want a complete inspection of the septic system to determine if it is in compliance with local rules and regulations. Not sure where the OPS is located, but where I live (MA) a septic system inspection is mandatory, paid by the owner of the house, prior to sale.
At least in my area, the local Board of Health has the best records about the design and location of the septic system. Again, no idea where the OPS is located, but the place to start to review septic system installation records is with the Board of Health. If there is no Board of Health, or there are no records, things get more difficult. From the description of the process, the first three companies had no idea where the tank was, suggesting either there are no plans on record, or the companies failed to review the plans before beginning their search, or the plans on record were not accurate.
As to whether a tank can be under a driveway, from the posts it should be clear that local regulations vary considerably, so there is simply no way to make a blanket statement as to whether a tank under a driveway is acceptable. It is accurate to say that from a design standpoint, any tank under a driveway needs to be designed to withstand vehicle load, and not just a car, but a load such as a dump truck. In my town, you can put a tank under a driveway as part of the permit process, but the tank need to be rated for H20 loading, and the cover needs to be at grade (accessible). Your local regulations are likely to vary.
Recommendation: Talk to the local Board of Health. Review the plans on file if there are any. If you still want to pursue the house, hire a local, authorized septic inspector to prepare a written report on the condition of the system. Ask the inspector to prepare a written cost estimate to bring the system up to compliance with current standards. If still interested in the house, negotiate a price consistent with performing necessary work to bring the system into compliance.
The Following 4 Users Say Thank You to Daniel Holzman For This Useful Post:
craig11152 (12-10-2015), dd57chevy (12-11-2015), mtarallo (12-11-2015), Tom738 (12-10-2015)
Old 12-10-2015, 11:42 AM   #13
ZTMAN's Avatar
Rewards Points: 480
Dan's recommendation pretty much hits the nail on the head. Inspect, assess, and decide
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
Old 12-10-2015, 01:54 PM   #14
Rewards Points: 5,010
In my neck of the woods.
No info, I would walk away.
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
Old 12-10-2015, 04:48 PM   #15
And what does that have to do with access to your septic tank???? Answer: absolutely nothing.
Time to replace hot water tank - options eastcan Plumbing 2 09-26-2013 07:32 AM
septic - could you fill a 1500 gallon tank in 10 months? denemante Plumbing 20 12-10-2012 05:16 PM
Garage over Septic tank and Leach lines canyonbc Building & Construction 11 01-13-2010 11:48 PM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 12:33 PM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 10:08 AM
