Septic Tank - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 05-25-2018, 10:29 PM   #16
Rewards Points: 4
Re: septic tank
I see where the confusion came from- my bad! I'm asking these questions for jaci.
Sent from my VS988 using Tapatalk
t.carpenter00 is offline   Reply With Quote
Old 05-25-2018, 11:14 PM   #17
Super Moderator
joed's Avatar
Rewards Points: 30,500
Re: septic tank
Originally Posted by t.carpenter00 View Post
I didn't read that the tank is abandoned. Is it.
I'm asking questions because I'm a licensed septic installer /inspector of about 25 years. There are just more info needed than has been provided, that's all.
We are talking about replacing a tank that is under a house. Abandoning the under house tank was maybe mistakenly assumed.
Old 05-25-2018, 11:48 PM   #18
Rewards Points: 4
Re: septic tank
Well, if the system works properly, chances are good it doesn't need pumped- bacteria should be doing thier job. In Missouri, unless you have 10 acres or more (generalizing here) you have to get a permit to modify your system. Then you'll likely have to update it.
If it's not working slow, or smelling, I wouldn't mess with it.
I once had a septic system that consisted of a 55 gal plastic barrel and 100' of lateral. Used that for 10 years with 2 kids.
I routinely inspect systems 10-20 years old with 6-8" of sludge in the bottom of the tank- never been pumped. Looked at one 2 wks ago, in fact.
If it ain't broke-don't fix it.
Old Septic Tank davemax Plumbing 3 07-08-2014 06:46 PM
rain water entry direct into septic tank? denemante Plumbing 7 03-13-2013 03:52 PM
septic tank problems. littles Plumbing 1 02-24-2010 10:30 PM
Garage over Septic tank and Leach lines canyonbc Building & Construction 11 01-13-2010 11:48 PM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 10:08 AM
