Securing Closetmaid Shelves - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By ktownskier
Old 06-04-2019, 07:36 PM   #1
Rewards Points: 676
Securing Closetmaid shelves
I installed these closetmaid shelves in my apartment. The horizontal part of the shelf sits on small plastic platforms. The small plastic platform is secured to the vertical legs of the shelf with metal dowels.
The problem is the horizontal part of the shelf is not secured to the small plastic platform. Sometimes when I pull something off the shelf, the whole shelf slides forward.
One quick solution is just hot glue gunning the shelf to the plastic platform. The platform is way to small for a screw or nail.
Any other ideas?
And no those aren't my clothes. ;>
Securing Closetmaid shelves-coastal-teak-closetmaid-wood-closet-systems-3272-64_1000.jpg   Securing Closetmaid shelves-coastal-teak-closetmaid-wood-closet-systems-3272-4f_1000.jpg
jaketrades is online now   Reply With Quote
Old 06-04-2019, 07:49 PM   #2
retired framer
Rewards Points: 14,798
Re: Securing Closetmaid shelves
I have put a tiny nail in the back behind the little tab sticking out. one one each side.
jaketrades likes this.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
jaketrades (06-05-2019)
Old 06-05-2019, 08:54 AM   #3
Rewards Points: 1,489
If this is what you mean by platform, then yeah, hot glue is the easy button.
huesmann is online now   Reply With Quote
Old 06-05-2019, 10:09 AM   #4
Rewards Points: 676
yup that's it. Didn't know what they were called.
Old 06-05-2019, 06:10 PM   #5
Rewards Points: 720
It's either thingamajig, or whatchamacallit.
Actually, it is called either Clear plastic - square type shelf pin or peg
I know a little bit about a lot of things. What I don't know, I research.
The only stupid question is the one you DON'T ask!
Most of all, have fun! It ticks people off and ruins their day.
As a technical writer, I tend to be lengthy in my responses as I want to be accurate.
ktownskier is offline   Reply With Quote
Old 06-05-2019, 11:19 PM   #6
Mystriss's Avatar
Rewards Points: 2,778
Make sure you check the size shelf pen you need, there is a 5mm and a 1/4" size.
That said, I put this shelf liner/tool box drawer liner stuff on the pegs so the shelves don't slide off - https://www.amazon.com/Tact-Brand-10...-6-spons&psc=1
I've also used adhesive cork sheet, but it doesn't work quite as well.
They also make these - https://www.amazon.com/Support-L-Sha...ateway&sr=8-10 - that you can screw into the shelves if you don't plan on adjusting them very much.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
