Seam Sealer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-05-2009, 03:28 AM   #1
seam sealer
when installing a floating vinyl floor do you just tape the seams or do you use a seam sealer like with plain sheet vinyl
phatibs01 is offline   Reply With Quote
Old 04-05-2009, 07:55 AM   #2
Vinyl will curl as it ages/dries out, seam sealer glues the two pieces together and eliminates or puts the problem off for a long time.
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 08:29 AM
Need to tint Xylene based sealer - Help!? miami Painting 8 10-01-2009 01:36 PM
Drywall Mudding Challenge: Seam vs. Tapered Corner cjakins Drywall & Plaster 3 03-10-2009 01:41 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
I'm going to end up with a seam of greenboard meeting plaster, how should I finish? J187 Building & Construction 2 06-06-2006 08:53 AM
