Screw Anchors For Metal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-25-2017, 04:39 AM   #1
Rewards Points: 16
Screw anchors for metal
I have to attach a microswitch made of plastic to the back wall of my convertible. However, to attach it I need to drill two holes. The problem is that I have no way to reach behind the hole in order to hold some kind of a bolt into which the screw could go. Is there any kind of screw for metal that when Snapskrus ,Snaptoggles ,Alligator as shown in this page http://www.popularmechanics.com/home...ind-that-wall/ that will work for metal?
salilsurendran is offline   Reply With Quote
Old 06-25-2017, 07:39 AM   #2
Rewards Points: 558
Re: Screw anchors for metal
Search for Jack Nuts. There are variants. But for a small switch, why not just auto grade double side tape? There is also kind of plastic rod clamp - a kind used often to hold cooling fans to the radiators.
carpdad is offline   Reply With Quote
Old 06-25-2017, 07:44 AM   #3
Property Mgt/Maint
Rewards Points: 7,626
SS sheet metal screws have been around for about 100 years.
Yodaman is online now   Reply With Quote
Old 06-25-2017, 07:48 AM   #4
Rewards Points: 3,664
The pop rivet may be an option.
Nail Shear Strength Test ddawg16 Building & Construction 32 08-24-2012 10:17 PM
How to remove screw stuck in the wood? higv2000 General DIY Discussions 13 06-30-2012 02:40 PM
Input for a Screw Guide Card marriomi Carpentry 5 06-28-2012 12:05 PM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 05:31 PM
