Sandpaper Grit Equivalent Of Steel Wool Grades - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SeniorSitizen
Old 10-04-2019, 05:51 AM   #1
Rewards Points: 259
Sandpaper grit equivalent of steel wool grades
For those who use both steel wool and sand paper, what would be the sandpaper grit equivalent of:
Steel wool grade 0000
Grade 000
Grade 00
Grade 0
Druidia is offline   Reply With Quote
Old 10-04-2019, 08:32 AM   #2
Rewards Points: 3,582
Re: Sandpaper grit equivalent of steel wool grades
No way to compare the 2 unless you can find sandpaper to be the same hardness as steel wool.
Example: I can clean our Formica counter top with 0000 and WD-40 but I wouldn't touch it with any type of sandpaper regardless of grit.
Bud9051 likes this.
Old 10-04-2019, 10:05 AM   #3
Rewards Points: 8,082
I did find some cross references between steel wool and sand paper, but they also commented that the two are used for different applications. If we knew what you were working on, wood, metal, maybe that would affect the replies.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 10-04-2019, 10:34 AM   #4
Rewards Points: 259
I use 0000 steel wool too when cleaning surfaces (in combination with WD-40, Goo Gone, oil/wood polish, or some other non-aqueous liquid). But I canít use steel wool on surfaces that get wet because little bits of them left behind will rust and Iíll only know thereís some left when I see tiny rust marks later.
I want to use sandpaper on various surfaces (e.g., porcelain, ceramic, some hard plastic resins) that get wet. A lot of surfaces are mixed materials with tiny crevices/nooks so if a tiny sliver of steel wool gets trapped underneath something and gets damp, thereís going to be rust stain.
What grit doesnít scratch - 2000, 3000?
Old 10-04-2019, 10:45 AM   #5
I've done some polishing but not a pro at it, but sounds like you might use a polishing compound.
But to answer your question, here is a link that posts a crossover.
https://www.finewoodworking.com/foru...-to-sand-paper
Bud
Old 10-04-2019, 10:46 AM   #6
Originally Posted by Druidia View Post
What grit doesn’t scratch - 2000, 3000?
For your projects I'd probably try one of those grits using wet/dry, wet. And if I had a scrap piece that's where I'd experiment.The scratches will be there but just not visible to the eye, at least not mine without cheaters of some kind and that depends on the material too.
Mentioned previously, another option to possibly consider is rubbing compound or polishing compound. Rubbing being the coarser abrasive of the 2. At least that's how it was in the days of DuPont.
Old 10-05-2019, 06:05 PM   #7
Rewards Points: 298
Any grit sandpaper will scratch-that's what it's made for. the finer the grit,the finer the scratch. Wet sanding and buffing automotive paint,I wet sanded with 1500,then applied rubbing compound,which does away with the scratches.
flhtcu is offline   Reply With Quote
Old 10-05-2019, 06:36 PM   #8
Property Mgt/Maint
Rewards Points: 7,586
For polishing I prefer 3M's Scotch-Brite. Steel wool is good for the mouse holes.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 10-05-2019, 06:57 PM   #9
Oso954's Avatar
Rewards Points: 878
They make bronze wool. Itís been used for years in the marine industry to avoid the rusting of steel wool.
Any good marine store will have it, as does Amazon.
https://www.amazon.com/HOMAX-PRODUCT.../dp/B0000AXS0Q
Oso954 is offline   Reply With Quote
