Rough Sawn Timbers - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 4 Post By jlhaslip
Old 12-02-2017, 12:44 PM   #1
Rough sawn timbers
I have 1 month old rough sawn timbers built into an outside stair case... Eventually I will sand, stain, and seal. Wondering if I should throw on some Thompson's today (55d) before it snows tomorrow and winter arrives... Or let them weather for a winter?
Goofydad is offline   Reply With Quote
Old 12-02-2017, 12:48 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Rough sawn timbers
I would not be using Thompson Water Seal on them except to seal the ends and/or cuts.
Using it on the top/bottom/sides will affect their ability to be stained/painted later since Thompson is a wax emulsion.
Using it to seal any exposed end grain will reduce checking and warping.
ChuckF., mark sr, That Guy and 1 others like this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 12-02-2017, 01:43 PM   #3
Thanks... I was thinking the same thing. Ill just hit the ends and cuts.
The Following User Says Thank You to Goofydad For This Useful Post:
jlhaslip (12-02-2017)
Old 12-02-2017, 02:20 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,902
If you use thompsons nothing else will stick in the future.
Old 12-02-2017, 03:05 PM   #5
Thanks for the info... I went ahead and just sealed the ends of the posts. I'll be covering with solar light caps anyway so figured it was better to be safe rather than have my stairs split on me.
Pics for reference...
Rough sawn timbers-20171202_140024_1512248677256.jpg   Rough sawn timbers-20171202_140101_1512248699557.jpg
Old 12-02-2017, 05:14 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 570
Ayuh,..... What species,..?? 1 month since the build,..??
How long ago sawn,..??
Air dried at all, or still green,..??
We recently did abuncha 8x14" hard maple, 10'ers, 12'ers, 'n 14'ers,...
Logs were 6 months down,...
Sawn, 'n installed last summer in a yoga studio,....
Overkill, but beautiful stuff,...
Bondo is online now   Reply With Quote
Old 12-03-2017, 08:25 PM   #7
Msradell's Avatar
Rewards Points: 1,006
Hopefully they had been cut a lot longer ago than one month. Otherwise they are going to be twisting and bending considerably over the winter. You don't want to use green lumber for a project like that. It should take at least 6 months, preferably a year before being used unless it's kiln dried.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 12-04-2017, 02:41 AM   #8
retired framer
Rewards Points: 8,670
I hope you have a plan for flashing the deck at the house. That is pretty but it is built in trouble.
Old 12-04-2017, 03:32 PM   #9
Answering questions...
1 month since install.. Purchased from commercial lumber supply house
So... IDK how long and/or type of drying process they had before selling to my contractor but they do not appear to be very green at all (ie: not soft or leaking sap)
Flashing at the deck - Yes, and Smartside siding is in process of going on.
Re: Thompsons... I decided to just apply to the 'top' of the vertical posts (which will be covered with solar lights in the future anyway after handrail install); and I did hit the cut ends at the base of the stairs which would be exposed to snow/rain directly on the landing; might taking a little sanding on those ends next spring - but thought I should be safe since those ends will be directly impacted.
Good timing as we got 8" snow here today... Winter arrived.
Thanks again for all the feedback...
As soon as my contractor is done with the siding and finish's installing the man and garage doors... I'll be working on getting electrical done.
Then the questions will REALLY start!!!
Rough Sawn wood for exposed beams Daugela Carpentry 7 09-26-2016 12:54 PM
painting rough sawn spruce fence boards soulja20 Painting 2 10-11-2011 11:13 AM
when will rough sawn spruce start to rot? soulja20 Carpentry 2 10-07-2011 08:10 AM
rough sawn lumber for hardwood floors david1031 Flooring 1 01-10-2010 07:20 AM
Replicating rough sawn wood bluefitness Painting 1 01-28-2009 09:54 PM
