Rotted Studs, Baseplate, Sub Floor Replacement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-27-2017, 11:35 AM   #1
Rewards Points: 2
Hi Everyone!
I had a leaking window that has been fixed, but am now dealing with the damage from the leak.
Some studs near the window and also the base plate and tops of the joists have rotted. As you can see in the images, I have cut the studs and base plate to get to good wood.
The top inch or two of the joists nearest the wall have rotted or are soft in about an 8-10 inch section.
What is the recommended procedure for me to install a new subfloor over this section and also fix the studs? I am thinking I can insert new 2x4's at the bottom of the studs and sister a stud to them for support, but how do I address the fact that I dont have solid wood or a flat surface at the top of my joists in this small area?
Thanks in advance!
Chad
Rotted Studs, Baseplate, Sub Floor Replacement-img_0783.jpg   Rotted Studs, Baseplate, Sub Floor Replacement-img_0782.jpg
chadmmiles is offline   Reply With Quote
Old 11-27-2017, 11:56 AM   #2
retired framer
Rewards Points: 6,260
Re: Rotted Studs, Baseplate, Sub Floor Replacement
You have a few problems. Brick absorbs water and needs a path between the brick and the house so water can make it's way to the bottom and out the weep holes.
I would guess the foam was doing that. So you will need a plan for repairing that.
Two of the studs beside the window are load bearing and are the most important.
Your plan for just pieces with scabs will work but first you have to deal with the soft rim joist as that will not support those studs.
I think I would be cutting out the rim joists and go a few more inches both ways to get out of the black stuff. Then it would be best to replace them with really dry pieces, some times used is better than new wet because the wet will shrink.
I sure loos like there is nothing under the edge of the sub floor along the wall, strange.
You might wash the black off with a detergent but you do not know how bad it is on the far side.
Need to figure out best way to replace rotted bathroom studs from inside Rashid Williams Building & Construction 31 07-13-2015 12:30 PM
Reparing rotten plate and studs ceford Building & Construction 0 02-08-2015 09:46 AM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 11:35 PM
Repairing rotted studs against exterior wall sleepyscout Carpentry 11 07-01-2009 02:31 PM
