Rivet Type On Torque Wrench - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By JIMMIEM
  • 1 Post By lenaitch
Old 05-16-2019, 07:05 AM   #1
Rewards Points: 45
My torque wrench is not clicking and I want to repair and recalibrate. This requires removing the head with the clicking mechanism. Most wrenches have a screw holding the head to the rest of the body. Mine has some sort of rivet because the two sides don't unscrew. It seems strange to put a permanent fastener where disassembly is needed.
Anyone know how to take off this fastener. My instincts are to grind or hacksaw the thing and replace with nut/bolt.
https://www.dropbox.com/s/p72u90j4ks...50982.JPG?dl=0
https://www.dropbox.com/s/ku8afeuuf0...50981.JPG?dl=0
https://www.dropbox.com/s/e5ek3mva78...50980.JPG?dl=0
atw58 is offline   Reply With Quote
Old 05-16-2019, 07:20 AM   #2
Rewards Points: 7,237
Re: Rivet Type On Torque Wrench
Is it meant to be serviced? I suspect not.
Answering your question I would use my Dremel and several metal cutting disks (they break easy) for the cleanest cut possible. Either of your choices might work with some minor damage to the tool.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 05-16-2019, 07:27 AM   #3
Rewards Points: 45
Good point about the expectation on being serviced. All the videos I've seen on recalibration show torque wrenches with screws. Never expected one to be not serviceable.
Also like the thought about using a dremel. I might grind most of it off then finish with the dremel.
Old 05-16-2019, 08:17 AM   #4
JUSTA MEMBER
Rewards Points: 4,760
Rivets are best Center punched, then drilled out in a drill press.
That said, some modern things are disposable for a reason.
Made from inferior materials, to be replaced when they wear out.
It's a built in obsolescence thing to keep selling new stuff.
ED
de-nagorg is online now   Reply With Quote
Old 05-16-2019, 09:30 AM   #5
Rewards Points: 692
What brand? HF has them for $9.99 on sale. I bought a couple and tested/calibrated using a weight plate. Not bad for the price.
de-nagorg likes this.
JIMMIEM is offline   Reply With Quote
Old 05-16-2019, 11:15 AM   #6
Rewards Points: 45
Could not find any brand/model marked on the wrench. Think I bought it for $30 on ebay many years ago.
HF unit is a great deal. Unfortunately I am in Canada.
Old 05-16-2019, 04:37 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,688
Ayuh,...... It's a cheap throw-away wrench,......
Bondo is online now   Reply With Quote
Old 05-16-2019, 04:53 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 4
Bought this one for our S-in-L for Christmas. Pretty well reviewed and accurate enough for most purposes.
https://www.amazon.ca/TEKTON-24335-2...00C5ZL0RU?th=1
I have a Snap-On dial wrench from about 1970. Still accurate within a couple of pounds - good enough for my purposes.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 05-16-2019, 06:55 PM   #9
Rewards Points: 8,194
A rivet is slightly cheaper than a screw. That was the motivation when they made it. I would probably grind away the head as best I could and then try punching it through.
SPS-1 is online now   Reply With Quote
Old 05-19-2019, 08:33 AM   #10
While the above is true; a properly installed rivet also contains no sharp edges to open the door for some shyster to sue the company because someone got a scratch and too stupid to properly care for it.
Colbyt
Old 05-19-2019, 10:05 AM   #11
Rewards Points: 4,590
I think the only thing needed here is to located under the piece that the two phillip head screws.
https://redirect.viglink.com/?format...1.JPG%3Fdl%3D0
ron45 is online now   Reply With Quote
Old 10-17-2019, 01:28 PM   #12
Rewards Points: 2
Connoisseurs help! I want to buy a click dynamometer key, for my tasks I have a key with a range of 19 to 110 Nm plus minus. Puzzled by the following, there are keys manufactured by Intertool, Aloid, Matrix and other Chinese products of low price range in the appendages of 25 bucks, there is no calibration passport and they could not be checked during manufacture.
Sigel123 is offline   Reply With Quote
Click Type Torque Wrench Calibration Brain Cramp JIMMIEM Tools 4 10-05-2017 01:12 PM
150 ft lbs of torque for a lugnut Bigplanz Automotive Repairs 16 12-31-2016 09:32 AM
How much torque to use on deck bolts? Deck Carpentry 12 07-31-2016 10:11 AM
Type B vent M/F end vertical positioning amakarevic HVAC 5 09-22-2011 09:48 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
