Rivet For Soft Materials? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-24-2016, 10:38 AM   #1
Rewards Points: 1,114
Rivet for soft materials?
Hi;
I need to fasten a length of Closed Cell Foam (CCF) to a weight lifting belt.
I want to use rivets, but I need something - large washers, or special rivets, so that the foam doesn't pull off the rivet when it is flexed.
The ideas I have come up with so far are:
Large (felt maybe) washers between the rivet and the foam
Nylon webbing between the rivet and the foam
Special type of rivet.
Any suggestions?
FW
Edit: Should I be looking at Double Cap rivets rather than pop rivets?
Ultrarunner2017 is offline   Reply With Quote
Old 08-24-2016, 11:34 AM   #2
Rewards Points: 144
Re: Rivet for soft materials?
Get the rivets in the size you want and get some SAE flat washer that fit the rivets.SAE washers have a small hole and a large shoulder.
mako1 is offline   Reply With Quote
Old 08-24-2016, 11:51 AM   #3
JUSTA MEMBER
Rewards Points: 3,476
You can buy WIDE Velcro at any sewing center.
This works well for any wearable attire.
ED
de-nagorg is offline   Reply With Quote
Old 08-24-2016, 01:24 PM   #4
Velcro is probably my best bet, as it would allow me to separate the foam from the belt when I need to clean them.
I may need to sew the velcro onto the belt though. I don't think the adhesive will stick to the fabric covering.
Old 08-24-2016, 01:51 PM   #5
Rewards Points: 4,082
I want to start earlier - why do you need to attach foam to a weight lifting belt?
stick\shift is online now   Reply With Quote
Old 08-24-2016, 07:05 PM   #6
Rewards Points: 1,744
Check car parts places like O'Reilly's, cars use plastic push rivets and other fasteners on door panels, underhood insulation, under-engine covers, radiator shrouds, etc. Look in the generic parts section where they have all those things on bubble packs.
ChuckF. is offline   Reply With Quote
Old 08-24-2016, 07:14 PM   #7
Rewards Points: 7,160
I think you mean fender washers. SAE washers are barely bigger than the head of the screw that they normally fit on. USS washers are somewhat bigger than SAE.
SPS-1 is offline   Reply With Quote
Old 08-24-2016, 08:14 PM   #8
Rewards Points: 2,535
Their is such a thing as a soft set rivet. They are designed for fastening soft materials. They are made of a softer metal that breaks off sooner, rather than pulling through. I don't know anything about closed cell foam, though. I don't know if it would work. Maybe combine that with the washer idea.
mathmonger is offline   Reply With Quote
Problem remove a rivet Toller Metal Fabrication 5 09-07-2015 08:19 AM
Electrician materials markup ashebrook Electrical 54 03-02-2012 08:46 AM
Materials Estimating/Lumber Takeoffs stubits Building & Construction 6 03-25-2010 06:10 PM
Help with hollow rivet max6166 General DIY Discussions 4 10-22-2009 09:18 AM
Right materials to patch plaster on masonry? jimhome Remodeling 3 06-08-2009 11:23 AM
