Replace Gerber Shower Cartridge - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-23-2013, 06:40 PM   #1
Rewards Points: 52
Hi Everyone,
I have a leaking shower faucet so I went to the local plumbing supply store, spoke to the owner and left with two new valve cartridge parts to replace. I have never done this type of repair before so I was hoping to get some clarification. I have attached several pictures including the type of Gerber handle (single), the current valve cartridge, and the two new parts I was provided. My question is whether the old parts just pull straight out and the new ones slide in or if there is more to it than that (such as removing additional pieces from the handle.
I would appreciate any insight that can be provided. I have to shut off the water for the entire 6 unit building to make the change so I want to make sure I understand what I should be doing. Thanks!
MK_Chicago is offline   Reply With Quote
Old 11-24-2013, 10:13 AM   #2
I sure hope we get some responses to this thread. I have a similar repair to do.
However, I not luck enough to have a name-brand unit (Gerber). Mine is a Kohler
knock-off called 'MIXET'.
oldgearhead is offline   Reply With Quote
replacing shower cartridge crankbait09 Plumbing 27 07-20-2012 08:37 PM
Moen cartridge repacement - single handle shower sandmant Plumbing 15 08-27-2011 09:09 PM
Replace Shower Stall with Tub on Cement Slab Kat58 Kitchen & Bath Remodeling 3 03-10-2011 11:55 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Need help replacing shower cartridge MrAngles Plumbing 7 03-01-2009 02:38 PM
