Replace Dyson Charger Plug - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-13-2019, 01:31 PM   #1
Rewards Points: 134
Are there after market plugs that I can use to replace this broken plug on Dyson Vac charger?
I donít even know what the proper name of it is to search! It plugs into the DC59 vac and the other end transforms AC to DC.
Vanner is offline   Reply With Quote
Old 04-13-2019, 02:24 PM   #2
Oso954's Avatar
Rewards Points: 882
Re: Replace Dyson Charger Plug
If you have a big electronics store nearby, take it in there and ask.
For me, between time and distance, bridge tolls, etc, I wouldnít waste time and money looking for it. Iíd just order the replacement charging unit.
https://www.amazon.com/Genuine-Dyson.../dp/B07C93P79K
Oso954 is offline   Reply With Quote
Old 04-13-2019, 10:53 PM   #3
Rewards Points: 134
I hear you on the time burn but trying to cut down on what goes into the waste system.
Old 04-14-2019, 09:10 PM   #4
Rewards Points: 1,900
There are about ten sizes of those DC adapter plugs, you have to identify it by the outside diameter and the inside diameter. It's an aggravation.
ChuckF. is offline   Reply With Quote
Old 04-15-2019, 12:51 AM   #5
Mystriss's Avatar
Rewards Points: 4,890
https://www.dyson.com/support/journe....64961-01.html
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 04-15-2019, 08:42 AM   #6
Rewards Points: 2,164
If it's just the casing that's come loose, and the wires still actually work, I'd be tempted to just encase it in some epoxy.
huesmann is offline   Reply With Quote
How to wire a 4-prong dryer plug stripedbass Electrical 79 03-15-2017 01:35 PM
250V 30amp 3 post plug on a bandsaw, change the plug to a 4 post plug question benjeremiah Electrical 3 10-04-2012 12:43 PM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 10:03 PM
