Repairing Leaky Metal Roof - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 12-19-2017, 04:24 PM   #1
Rewards Points: 6
Repairing leaky metal roof
The roof above a sun porch on a house I own has a small leak. The house was built in the 1890s and the roof is metal, and possibly original to the house. I assume it's tin, although it may be a different metal.
The leak appears to be the result of some small pinholes scattered around the edge of the roof.
My question is how you repair this permanently. I gather that a well maintained metal roof -- which means one that is regularly recoated with roofing cement -- should last indefinitely. So, before shelling out a fair amount of money to have the existing roof torn up and replaced with new metal, I'm inclined to spend more like $100 giving it a new layer of roofing cement.
But if the problem is likely to recur, then I'd rather fix it the right way -- or at least in a way that will last for many years. It's a rental property and I don't want to count on the tenants to report any new leaks, because they might not tell me until the problem has gotten pretty bad.
So, what do I do: Recoat the roof or hire someone to tear it off and replace the metal? Or is there another solution? Cost is important so I'm looking for a solution that will be cost-effective but not just a band-aid patch.
The roof is basically flat, by the way.
gadolphus is offline   Reply With Quote
Old 12-19-2017, 04:53 PM   #2
JUSTA MEMBER
Rewards Points: 1,576
Re: Repairing leaky metal roof
Needs a thorough inspection for signs of rusting, Many pinholes sounds like a possible rusted out sheet.
If so, no amount of tar is going to help.
You know the real answer, so just bite the bullet and replace it.
ED
de-nagorg is offline   Reply With Quote
Old 12-19-2017, 05:00 PM   #3
retired framer
Rewards Points: 6,146
You really need a trusted pro to look at it and give you advice, Almost flat does not sound like a good place for a metal roof.
Old 12-19-2017, 05:02 PM   #4
jlhaslip's Avatar
Rewards Points: 708
Is the year a typo?
1890 or 1980 ???
If 1890 is correct, you have received good value for the roof. Time to replace it.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 12-19-2017, 05:54 PM   #5
Rewards Points: 18,382
Not one picture in the post.
We can not see what your seeing.
What type metal roofing?
There's at least 7 different types.
mark sr likes this.
Old 12-20-2017, 06:56 AM   #6
custom user
Rewards Points: 1,820
You can repair an ancient roof until you get tired of it and decide to replace it. Only you knows where that threshold is.
JasperST is offline   Reply With Quote
Tags
metal roof , roof
Adding deck roof to existing metal roof billybarty Roofing/Siding 2 03-08-2013 07:50 PM
Leaking Metal Roof debisans Roofing/Siding 1 10-23-2012 07:44 PM
Not venting a metal roof. maestro Building & Construction 16 12-13-2011 03:31 AM
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 06:39 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
