Repair Or Replace? Small Rust Spot On BathTub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-01-2020, 01:00 PM   #1
Rewards Points: 24
Repair or Replace? Small Rust Spot on BathTub
Hey All -
So looking for some advice, I've called a few pros and sight unseen they simply suggest replacing the tub and of course that results in some tile work. In my case, all the tile would also need to be redone to get the tub out. None suggested or seemed receptive to any repair options. Is that because they don't exist?
The home was built in 1999, it must be some sort of porcelain over steel I suppose.
Here's the spot in question, any ideas on how to best handle? I want to keep the rust from spreading and getting worse if possible....
Damaged Spot:
https://imgur.com/C6yQIIL
Overall Tub:
https://imgur.com/T9vbhz4
mark1210 is offline   Reply With Quote
Old 01-01-2020, 01:24 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 772
Re: Repair or Replace? Small Rust Spot on BathTub
They make a simple porceline type enamel at any hardware store...expressly for your chip...even in different colors.
(The drywallers dropped a hammer or something on my son's new tub...the paint worked fine for 5 years so far.
MTN REMODEL LLC is offline   Reply With Quote
Old 01-01-2020, 01:28 PM   #3
Rewards Points: 24
Thanks so much for the reply.... sounds like its a good long term fix. I'll check out my local Lowes or HD.
Old 01-02-2020, 06:05 AM   #4
Rewards Points: 554
I have a small rust spot at the drain cover and searching around to see if there's something better than glorified nail polish at the box stores. Rust always came through after while. I have not used the attached material. I just found it from amazon. Fairly good number of reviews. I plan to try this, but it is something I never used before. At your own risk. I'm renovating my home and want to keep the old cast iron good finish tub, so am thinking it is worth the cost, but waiting until I'm ready to replace the drain parts. Then I can apply the coating throughout that part. If I coat just around the existing metal drain, rust under it will come back.
carpdad is offline   Reply With Quote
Old 01-02-2020, 07:34 AM   #5
Naildriver
chandler48's Avatar
Rewards Points: 1,340
I agree with the repair. Remember your tub must be drawn out of its opening and stood on its end to remove it from the room. Is that a possibility? Most likely not. Damage to the tile will render the wall unusable, as tile matching will be very difficult if not impossible.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
