Removing Trashcan Wheel - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 3 Post By lenaitch
  • 2 Post By MTN REMODEL LLC
Old 09-08-2019, 02:20 PM   #1
Rewards Points: 215
Removing trashcan wheel
I have an old Rubbermaid wheeled trashcan that I use for yard waste. One of the wheels is broken. To remove the wheel, I first need to remove a small cap on the end of the axle. I can't seem to get it off. I've hit it with a hammer, soaked it in WD40, grabbed it and the axle with pliers and tried to pull it off. I would appreciate any advice on removing this darn thing. I will attach a photo.
Thanks in advance.
bucksone is offline   Reply With Quote
Old 09-08-2019, 02:26 PM   #2
Rewards Points: 2,402
Re: Removing trashcan wheel
Try applying heat with torch then tap off with hammer alternating sides. You could also use a small flat tip screwdriver to pry off the locking tab of the cap that's holding it to the axle. Keep trying, it will eventually come off.
jmon is offline   Reply With Quote
Old 09-08-2019, 02:28 PM   #3
retired framer
Rewards Points: 1,654
Use a box end wrench that just fit over the shaft and use that to hammer it off , try to get even pressure all around
Do not use flat bottom gables with scissor trusses.
Old 09-08-2019, 05:57 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 256
That's a push-on locking cap nut and the suggestions above should work. he challenge might be getting a decent swing with a hammer. They actually grab quite well. At worst you can take a hack saw and cut most of the way through it, or otherwise destroy it. Big box and hardware stores have bins full of them.
Msradell, mark sr and Nealtw like this.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 09-09-2019, 09:19 AM   #5
Rewards Points: 926
You can't get it off, but how'd you manage to take a pic of the thing? Appears to be no wheel. Unless your axle is just way longer than it needs to be.
huesmann is offline   Reply With Quote
Old 09-09-2019, 09:55 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 308
Do you have a grinder....it'll cut right thru it.
lenaitch and Nealtw like this.
MTN REMODEL LLC is online now   Reply With Quote
Old 09-09-2019, 08:51 PM   #7
Rewards Points: 215
Managed to get it off by putting it in a vise and using a hammer and a punch to knock it free.
The axle pops off the bottom of the can. When I held it vertically to take the photo, the bad wheel slid down the axle until it hit the good wheel. That's how I took the photo.
Old 09-09-2019, 10:23 PM   #8
Rewards Points: 3,170
buy a new can?
Originally Posted by Bud9051
Of course they had already been around for over 200 million years but on a planet that could go for billions of years maybe captain Kirk would have had big teeth and a long tail.
That Guy is offline   Reply With Quote
Old 09-12-2019, 05:14 PM   #9
Rewards Points: 8
this is what i did on mines
jasonfodor is offline   Reply With Quote
Old 09-12-2019, 06:13 PM   #10
Rewards Points: 308
Trade it with a neighbor...??
huesmann and Nealtw like this.
