Removing Old Chain Link Fence - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-14-2014, 04:36 PM
Rewards Points: 934
Removing old Chain Link Fence
We are putting up a pvc fence where this chain link fence is. What is the best way to remove this. I was going to cut the posts flush with the ground. Do I need to chop/dig up the concrete holding these posts if the new posts fall in a different location than the existing? Thanks.
Removing old Chain Link Fence-photo-1.jpg   Removing old Chain Link Fence-photo-2.jpg
Mstrlucky74 is offline
Old 09-14-2014, 06:07 PM
jproffer's Avatar
Rewards Points: 354
As long as they aren't in the way of the new ones, I would just cut them off as deep as I could and leave the rest.
jproffer is offline
The Following 3 Users Say Thank You to jproffer For This Useful Post:
Mstrlucky74 (09-14-2014), Nailbags (09-15-2014), r0ckstarr (09-15-2014)
Old 09-14-2014, 07:19 PM
Rewards Points: 2,620
There always seems to be someone looking for good pre-owned chain link, ( cheap ) of course. Advertise it for free but they must also take the post and concrete. Require a deposit. Written agreement , no verbal. If it's done to your satisfaction they get the deposit back. A sign on the front lawn might do it.
SeniorSitizen is online now
Old 09-14-2014, 08:52 PM
Rewards Points: 996
i would pull the posts out. but i'm funny that way. ask your family/friends. perhaps one of them can loan you an engine hoist. that will make short work of it.
Fix'n it is offline
The Following User Says Thank You to Fix'n it For This Useful Post:
Mstrlucky74 (09-15-2014)
Old 09-14-2014, 09:28 PM
Rewards Points: 144
Built many a chain link fence.Best to take the posts out.With the new fence you might think your going along well and missing the old one and then after several hit one.
The posts on chain link are a uniform distance from each other but not always on the foot.We would measure the length and divide to get anything under 8' and go with that as the spacing.
You will probably want your corners posts the same anyhow.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
Old 09-14-2014, 10:20 PM
Msradell's Avatar
Rewards Points: 912
I would definitely pull the posts out rather than cutting them off. It's pretty easy to pull them out if the entire post is attached to the concrete. Much more difficult later on when the post is cut off.
Written using Dragon Naturally Speaking
Msradell is offline
The Following User Says Thank You to Msradell For This Useful Post:
Old 09-14-2014, 10:40 PM
Rewards Points: 4
I also found it was much easier to pull the cement out with the post still attached.
gma2rjc is offline
The Following User Says Thank You to gma2rjc For This Useful Post:
Old 09-15-2014, 12:15 AM
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,712
They usually come out easier than you might think.
Windows on Wash is offline
The Following User Says Thank You to Windows on Wash For This Useful Post:
gregzoll (09-15-2014)
Old 09-15-2014, 12:49 AM
r0ckstarr's Avatar
Rewards Points: 82
Remove the fence. Soak the area around the post with water. Grab the post and start rocking it back and forth in all directions. Then lift it out.
Use a sawzall to cut the concrete portion off. Load everything in the bed of a truck and haul it to the scrap yard. I did the exact thing and got $45 for my rusty old chain link fence.
r0ckstarr is offline
The Following User Says Thank You to r0ckstarr For This Useful Post:
Old 09-19-2014, 11:32 PM
Jello Wrangler
Rewards Points: 539
Skip the water, just rock back and forth. The water can cause suction and that'll make it a beast to get out.
ChiTownPro is offline
Old 09-20-2014, 04:11 AM
r0ckstarr's Avatar
Rewards Points: 82
Wasn't a problem for me.
Old 09-20-2014, 01:20 PM
Jello Wrangler
Rewards Points: 539
How many have you removed in that manner? What was your soil? Black dirt, clay, sand...
It just makes for a messy demo and really isn't needed.
chain link on uneven ground novanoel General DIY Discussions 7 09-29-2015 03:02 PM
Chain link gate accross driveway mj12 General DIY Discussions 2 04-30-2013 06:55 PM
Link Chain Fence drodd Landscaping & Lawn Care 2 04-17-2013 11:56 AM
chain link fence post removal Designman20 Landscaping & Lawn Care 3 07-05-2007 10:52 AM
Chain link problem? jeremylindquist Landscaping & Lawn Care 1 06-24-2007 07:34 PM
