Removing Backerboard & Thinset From Subflooring After Ceramic Tile Removal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-06-2015, 07:27 PM   #1
Rewards Points: 6
Removing backerboard & thinset from subflooring after ceramic tile removal
Location is Harrison Twp, Michigan
We removed ceramic floor tiles. Is there an easy/productive way to remove
the backerboard that has been cemented {thinset} to the subfloor? Without removing the subfloor?
Please help!!!!
dotsmith1207 is offline   Reply With Quote
Old 05-06-2015, 07:48 PM   #2
Retired Moderator
Rewards Points: 7,174
Unless it is a huge floor , driving a flat bar under it with a hammer usually works.
A chipping hammer(looks like a drill) with a wide flat blade is a time saver if the floor is larger.
An angle grinder with a diamond cup will make short work of the thin set.
Old 05-06-2015, 08:13 PM   #3
Rewards Points: 6
It looks like there are places where liquid nail was used instead of thinset. is there a solution to remove the backerboard that has been glued to the subfloor?
Old 05-06-2015, 08:36 PM   #4
Retired Moderator
Nothing simple--wide chisle--painters tool----Might need some new subfloor
$30 a sheet might not sound bad after chipping away for a few hours.
Old 05-06-2015, 08:46 PM   #5
Rewards Points: 6
oh'mike.....yikes! Had that feeling. Yeah we don't want to make this a week long project of scraping/chipping away. Thanks for the input, it helped a lot!!
Tile over tile or use backerboard gbrady Flooring 4 02-04-2013 03:34 PM
Must old thinset be removed when replacing ceramic tile? Doofusboy Tiling, ceramics, marble 2 01-04-2013 09:52 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Backerboard, tile, tub installl kathyll Building & Construction 26 02-15-2011 08:35 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 09:39 AM
