Removal Of Shrubs - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Gregsoldtruck79
  • 2 Post By lenaitch
Old 06-12-2018, 10:16 PM   #1
Rewards Points: 118
Removal of shrubs
Hi
What kind of shrub might these be and how hard could it be to remove? Im thinking of calling a landscaping guy to shovel it out.
Thanks.
nilanjan is offline   Reply With Quote
Old 06-12-2018, 10:23 PM   #2
Rewards Points: 468
Re: Removal of shrubs
Privit maybe? Why do you want to dig it up?
Jim F is offline   Reply With Quote
Old 06-12-2018, 10:27 PM   #3
Rewards Points: 118
I want to replace them with some kind of evergreens- better privacy wall especially in winter bcs they wont loose leaves in and less maintenance.
Old 06-12-2018, 10:47 PM   #4
Rewards Points: 18,118
I deal with this type stuff all day.
If you called me I'd be using my nylon strap with two loops and pulling it out by the roots with my lawn mower.
If that failed I'd have my helper chop around the roots with an ax and and try again.
I've removed hundreds of shrubs and trees and it's rare we have to dig anything out.
Old 06-13-2018, 10:41 AM   #5
Rewards Points: 118
Im thinking... can I use a CR-V with a hitch to pull them out? Securing the strap on base of the shrub and the hitch then putting the CR-V on drive - little to no- gas. Would that work? Wouldnt want to kill the tranny.
Now by asking Im not suggesting Ill go ahead do this though .
Old 06-13-2018, 10:46 AM   #6
Rewards Points: 118
Anyone please suggest options for a maintenance free shrub that could act like a wall and not loose leaves in the winter?
I was thinking of using the tall Japanese Holly - I think they are called Sky Pencil.
Im open to suggestions as I dont wanna do this again. Thanks!
Old 06-13-2018, 11:01 AM   #7
Rewards Points: 22
I did not have a big PU truck or riding mower. So I used what I had to pull bushes....a 2 ton engine hoist. And luckily I pulled the big Holly bush I had it hooked to in the pic last of all, as it bent the lift beam some... but it came out.
SeniorSitizen likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 06-13-2018, 12:27 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 238
I’m open to suggestions as I don’t wanna do this again. Thanks!
Very little in life is "maintenance free"; you're better to look for 'low maintenance'. Different species do better in different areas. Shop around local nurseries or pay attention to neighbours if you see something you like and that might thrive in your climate zone and soil. If you want fullness year 'round, you're probably looking at a conifer.
Pay attention to how wide and high a species will grow. Many people fail to realize this and plant them too close to the fence, house, etc.
SeniorSitizen and dd57chevy like this.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 06-13-2018, 04:58 PM   #9
Rewards Points: 2,528
Pull the unwanted shrub and possibly plant a row of eastern red cedar of some cultivar for low maintenance and green. Visit your local nursery.
Old 06-13-2018, 05:47 PM   #10
Rewards Points: 118
Thanks - Ill look them up.
Are they deer resistant?
Old 06-13-2018, 05:54 PM   #11
Rewards Points: 118
I actually see a lot of aborvitae in the neighborhood. They were planted many years ago and they just keep growing taller and wider. Once you top one of those trees they just keep growing wider and wider. Otherwise they reach for skies.
Old 06-13-2018, 06:01 PM   #12
dd57chevy's Avatar
Rewards Points: 2,826
Not sure on PA's climate , (I think it's similar to mine) , but one of the classics is the arborvitae :
https://www.gardendesign.com/trees/arborvitae.html
Not as pretty as , say , a yew , but less maintenance & faster growing .
Like Lenaitch said , be sure of the particular species as to how big they get .
Editorial comment : one of the dumbest things (IMO) is when I see a pretty spruce or fir tree (or anything) planted too close to a house , fence , etc . "If it said right on the tag that it can grow 30" wide , that's a 15' radius......why'd you plant it 6' from the HOUSE ???"
Ok , I feel better now .
dd57chevy is offline   Reply With Quote
Old 06-13-2018, 06:06 PM   #13
The native eastern red cedar we have are not only deer resistant they are deer proof. Once again, a good local nursery will be able to provide necessary information about growth rate, height, pruning if needed, mature shape etc. In my opinion this would not be a good time to do an on line order.
Old 06-14-2018, 07:19 AM   #14
Rewards Points: 254
Mixed flower azalea always impressed me. I only know about established plants, but mine lived through summer dry times as well as being buried under plow snow. When I had to move them for retaining wall redo, they lived through that too.
carpdad is offline   Reply With Quote
Caulk removal tools used by pros? daluu General DIY Discussions 7 08-07-2016 06:32 PM
Advice on planting some shrubs. Austin83 Landscaping & Lawn Care 0 03-17-2013 12:09 AM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
