Reinforce 2x6 Garage Ceiling Joist - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By carpdad
Old 03-28-2018, 06:01 PM
Rewards Points: 2
Reinforce 2x6 garage ceiling joist
We have a flat roof 22x 28 flat roof garage that have 2x6 joist 12” oc. It currently has a support beam with post on 1/3 side. We need to take that out and have no support beams. Any ideas how can we reinforce the joist? Not much head room in garage to begin with.
Cole760 is online now
Old 03-28-2018, 08:33 PM
Naildriver
chandler48's Avatar
Rewards Points: 884
Re: Reinforce 2x6 garage ceiling joist
Nominal 6" lumber doesn't offer much support over 11' or so. Can you post a picture of your situation so we can see what you see? Do you have space above the joists, or are they butted up to the flat ceiling?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline
Old 03-28-2018, 10:56 PM
Rewards Points: 2
That’s the current beam that is supported by 2 post.
Old 03-28-2018, 11:47 PM
Rewards Points: 230
Could get expensive. One way is you can put beams between the joists to span the same length as the joists. Then just use the 6x6 beam. The lumberyard will help you with sizing the lvls. If that span is 22', my guess is double 2x12 lvl over the post locations. This means you need supporting studs in the wall if stick framed wall and make sure you have a proper footing. If the garage footing is continuous 24x12" at the frost depth, you're fine. If the garage is on slab only, you will have to put in 24x24x12" footing at the frost depth.
You can't put any more beam on the header over the door.
carpdad is offline
The Following User Says Thank You to carpdad For This Useful Post:
Cole760 (03-29-2018)
Old 03-29-2018, 12:07 PM
Rewards Points: 2
Here’s some more pics. Garage is actually 20x 22. 2x6 joist spanning 20ft.
Old 03-30-2018, 07:37 AM
Rewards Points: 230
Another option is sistering lvl to the joists. Not sure but check if there are charts for lvl. Also I think your joists are 2x8 (about 7.5"?). I'm confident that if you sister every 2 bays, you're set. But every 3 or 4 bays may be ok too based on your deck material. It's worth searching for. Your local yard may be able to help, and commit to that store, so it is also worth asking for prices and delivery cost. 20' lvl can be handled alone. They do cost, so I'm wondering if 4-5' space gain is worth it.
BTW, if you scrape off the gravel, and/or if you replace the roofing to modified roll roofing, your load requirement changes to your advantage. If the roof is flat, I'd try to put some slope there.
Cole760 likes this.
carpdad is offline
Attached Garage Ceiling Code? eagle107 Building & Construction 17 11-14-2015 10:44 AM
Insulating pipes in garage ceiling ? westbank HVAC 3 10-11-2013 06:43 PM
garage ceiling mferguson0414 Carpentry 2 01-13-2009 11:24 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 11:50 PM
