Refrigerater Screw Hole - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By huesmann
Old 09-13-2019, 11:00 AM   #1
Rewards Points: 2
Refrigerater screw hole
I bought a scratch n dent refrigerater. Apparently the handle on the freezer had been bumped hard. One day the handle broke. I noticed that the hole where the screw holds the handle on was damaged. I got a new handle, but if i put the screw in, it is going in at an angle. I'm afraid the new door handle will break again if I don't somehow fill in the hole and make a new one so the screw goes in straight. any suggestions what I can use to do this?
siso05@aol.com is offline   Reply With Quote
Old 09-13-2019, 11:15 AM   #2
Hammered Thumb
Rewards Points: 454
Re: Refrigerater screw hole
I'm used to seeing just sheetmetal over the foam insulation, so it's only held with the sheetmetal. If it's loose, I use a bigger screw, like going from a #8 to a 10 or 12, and it can be straightened too. Sounds like yours is solid, because if it was loose the handle probably would have a little play rather than break.
3onthetree is online now   Reply With Quote
Old 09-13-2019, 09:01 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 1,016
You could buy a longer Grade 8 bolt of the same size, insert it a few threads in the hole, and use pliers or something similar to bring the bolt to the right position. The reason for the stronger, longer bolt is that the cheap bolt provided would probably break while doing that.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-14-2019, 08:40 AM   #4
Rewards Points: 850
No pics is not helpful to diagnosing the issue. I'm picturing some thin sheet metal where the hole has been hogged out and possibly twisted by the impact? If so, flatten it out and use a washer. Done. If the receiving threads are damaged, upsize the screw. If by "screw" you really mean "bolt" or "machine screw" let us know.
SPS-1 likes this.
huesmann is online now   Reply With Quote
Old 09-14-2019, 12:21 PM   #5
Rewards Points: 2
Here is a picture of the hole
Refrigerater screw hole-image_1568478041858.jpg   Refrigerater screw hole-image_1568478078106.jpg
Old 09-14-2019, 02:02 PM   #6
Rewards Points: 8,472
So the screw goes in from the outside?
Try putting the new handle on. Really, if the screw goes in readily, I wouldn't worry about it. More likely, the old handle broke because it got "hit hard", as mentioned in the original post. If the handle does not sit properly because of the bent sheet metal you might have to tap it flat, or put the screw in and bend in the opposite direction. Or maybe fill the divot with a touch of epoxy to give the handle a level surface to sit on.
SPS-1 is online now   Reply With Quote
Old 09-14-2019, 02:32 PM   #7
retired framer
Rewards Points: 1,512
You could pull the liner and play body man and do a little dent repair.
Do not use flat bottom gables with scissor trusses.
Tags
compound , fridge , hole , screw
