Radon Mitigation - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree13Likes
Old 11-21-2017, 09:45 AM   #16
Rewards Points: 8,082
Re: Radon mitigation
That fan should work fine. Pick up a u-tube manometer at the same time, you need that to tell you how well the fan is working, air flow is not the way to judge. HD should have them as well.
Bud
shobuddy likes this.
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
shobuddy (11-21-2017)
Old 11-21-2017, 10:13 AM   #17
Rewards Points: 62
Bud
Couldn't find a manometer on the Home Depot website but I was saw this one on Amazon...should work, right?
https://www.amazon.com/RadonAway-500.../dp/B00HYZ28I6
shobuddy is offline   Reply With Quote
Old 11-21-2017, 11:31 AM   #18
That manometer will do just fine. Be sure the fan is above the manometer wherever you install it.
Bud
Old 11-21-2017, 12:39 PM   #19
Rewards Points: 62
Bud, got one more for you. Below is a excerpt from the contractor's email. Costs wise it sounds like the first option would be more expensive. In your opinion, which one should I choose?
Do you want to run a dedicated line from the Electric panel to the Radon Fan? (recommended)
-----this will require 70 feet of 14-2 wire and a breaker for the panel as well as an outlet box, duplex outlet and cover
Do you want to tap off a light fixture near the fan?
-----this will require 20-30 ft of 14-2 wire as well as an outlet box, duplex outlet and cover
Old 11-21-2017, 12:48 PM   #20
That is more of a code question. As for proper function I believe either will work and a Radon fan is not a life or death issue. It will be so quiet the only way you will know it is running will be to occasionally check that manometer, or at least it should be quiet.
If for some reason you wish to flip the breaker to turn it off that would kill everything else using that circuit if it is not dedicated.
Bud
Old 11-21-2017, 07:45 PM   #21
Rewards Points: 62
Bud
Thanks Bud, the contractor had recommended putting the fan in the basement itself but I talked to the code office and they said it has to be put in the attic.
Old 11-23-2017, 12:57 AM   #22
Rewards Points: 36
Bud
I've seen the need for a manometer mentioned many times but I have seen no mention of what the manometer should actually read for a proper installation i.e. is there a minimum or maximum inches of water reading?? I suppose a low reading might indicate too much slab leakage or at least that the fan is running and not plugged-off but OTOH a high reading may indicate there is little or no "contact" with some parts of the under-slab i.e. insufficient permeability in the sub-soil or gravel(?).
Laurie Forbes is offline   Reply With Quote
Old 11-23-2017, 06:53 AM   #23
The size of the fan, the initial radon reading, and the resulting reduction all get involved as well.
Bud
Old 11-25-2017, 07:39 PM   #24
Rewards Points: 36
Regards the timer switch, here's an excerpt from the RadonAway installation manual:
"7. WARNING! Do not leave fan unit installed on system piping without electrical power for more than 48 hours. Fan failure could result from this non-operational storage."
http://www.radoncontrol.ca/assets/rp...structions.pdf
Anyone have any idea why that may be a problem?
Old 11-25-2017, 08:20 PM   #25
Just a guess, but when operating the fan benefits from air flow and the heat it generates along with the warmth passing through. This heat and air flow probably helps to keep unwanted moisture from getting into places it isn't wanted, although 48 hours sounds like an unreasonably short time.
Basically it is a CYA statement to prevent builders and home owners from just installing the fan and forgetting it so it will be there if needed. 5 years later you apply the power and it's dead and they don't want to hear any complaints.
Bud
Old 11-25-2017, 08:23 PM   #26
Rewards Points: 36
I think that is a good guess alright.
Mold AND Radon mitigation boondocks95 General DIY Discussions 3 03-20-2016 03:10 PM
Side by side sump pit garrett1812 Plumbing 9 03-06-2016 09:24 AM
Radon soil gas, water w/radon, & other household air quality mitigation plans ylekyote HVAC 9 02-08-2016 04:46 PM
Radon Mitigation installed near AC Unit outside. Problem? majorchamp General DIY Discussions 16 06-30-2008 02:44 PM
