Question About Electric Winch - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 07-15-2018, 01:28 PM   #1
question about electric winch
A small window air conditioner was installed over a door, where there was a transom window. I need to get this down and install a new one. Can't do this on a ladder anymore. So simple answer is a winch but never used one. My question is, as in the image, how is the wire rope kept from spinning free when the heavy object is coming down? Motor only?
Also, I was thinking of using the ratcheting strap. If the strap is wrapped one way only, I guess about 6-7 times around the ac (getting 30' strap), will the ratchet get all 6-7 wraps of strap to tighten around the ac?
carpdad is offline   Reply With Quote
Old 07-15-2018, 02:02 PM   #2
Oso954's Avatar
Rewards Points: 286
Re: question about electric winch
There is a drum brake that keeps the drum from spinning when there is no power to the motor. You use the rocker switch to power the wire rope up or down.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
carpdad (07-15-2018)
Old 07-15-2018, 02:07 PM   #3
JUSTA MEMBER
Rewards Points: 302
Those winches are supposed to have auto braking , to prevent freespooling.
You will need to verify this before purchasing one, some manufacturers omit it to allow a cheaper unit.
What is the weight of the A C unit? an assistant would be handy, or more than one.
Whatever you do, do not get under it to lower it, if it comes loose, you will be harmed.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 07-15-2018, 02:26 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 958
You won't have room from the ceiling to the AC unless you have super high ceilings. Hire a couple of high school kids to remove it for you.
joecaption and dd57chevy like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Old 07-15-2018, 04:07 PM   #5
Thank you for the replies. Will take all cautions but helpers are liability, imo. Was hoping that AC would be the last dumb thing I do.
Nealtw likes this.
Old 07-15-2018, 05:51 PM   #6
Rewards Points: 2,526
Would a drywall lift with a plywood platform attached to slide the A/C onto work?
de-nagorg and Gregsoldtruck79 like this.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
carpdad (07-16-2018)
Old 07-15-2018, 06:45 PM   #7
Rewards Points: 18,118
Post a picture of what your up against.
I can not picture ever using a hoist for this simple 1/2 hour job.
Two step ladders, two people, in and out.
Old 07-16-2018, 09:15 AM   #8
Sorry no photo but it is above a door with a tricky location. The door is on a corner (wall on one side) leading out to a narrow (3') screened patio. 2 stories up. I also don't know anybody I'd be comfortable having accidents with.
Joe, I think I was planning myself into getting a new tool. Though I think this is the best option with nobody under the thing. I will be making the winch brace better than I described.
Thanks for all replies.
Old 07-16-2018, 10:02 AM   #9
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,258
rent a painters scaffold for half a day - two people - live to tell about it.
Colbyt likes this.
Johnny_inFL is offline   Reply With Quote
The Following User Says Thank You to Johnny_inFL For This Useful Post:
Old 07-16-2018, 10:08 AM   #10
Rewards Points: 164
This is one of those times you could probably pay someone to do it for what it would cost you for the winch. Not only that you will still need to get above the ac to mount the winch or a pulley.
comfun1 is offline   Reply With Quote
The Following User Says Thank You to comfun1 For This Useful Post:
Old 07-16-2018, 10:52 AM   #11
Super Moderator
joed's Avatar
Rewards Points: 29,512
Not cheap but you need something like this.
https://www.northerntool.com/shop/to...1838_200651838
The Following User Says Thank You to joed For This Useful Post:
Old 07-16-2018, 04:02 PM   #12
The lift cart type is the first thing I looked at but they tend to be heavy (have to go through the house, out to the bedroom patio), not very manuverable and for a single purpose. Same with the scaffold. Actually I had the words mixed up. The image is a hoist, not a winch. Found Champion hoist manual that clearly shows a brake. About the same price at homedepot. Wish I went to homedepot site also. Would have preferred champion that at least has an office and publishes a manual. Grainger also has a paper on the difference. Winch does not have a brake or has gears that may fail. Winch is not for verticle lifts. The amazon buyers seem to like it and use it to take thing up as well as down, so I assume it has some kind of brake.
I may return the amazon hoist if the manual is in chinese.
Old 07-16-2018, 04:19 PM   #13
Rewards Points: 22
Gregsoldtruck79 is offline   Reply With Quote
Old 07-16-2018, 04:33 PM   #14
A snatch block attached to a ceiling joist above the A/C and about 2 ft. out from the A/C will solve the distance problem between the A/C unit and the ceiling. By this the hoist can be mounted almost anywhere in the room. This will also allow the A/C unit to swing out to be lowered.
joed likes this.
carpdad (07-18-2018)
Old 07-16-2018, 11:13 PM   #15
Rewards Points: 4,796
Maybe.?
de-nagorg likes this.
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
Electric Baseboard Question Trader979 Electrical 8 11-29-2016 05:26 PM
Elevator for boxes of books electric winch or block and tackle (rope)? ArtStudent General DIY Discussions 2 07-01-2016 07:52 AM
Flip switch for electric winch? rocklobster Electrical 4 03-20-2016 09:03 PM
Electric Mat Radiant Floor Heating Question ryan5068 Flooring 14 09-03-2010 11:37 AM
