PT Lumber Concerns For Finished Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 4 Post By rrmccabe
Old 09-05-2018, 10:51 AM   #1
Rewards Points: 12
PT Lumber Concerns for Finished Ceiling
The lumber yard screwed up and delivered AC2 pressure treated instead of traditional framing 2x3s for my basement project. I plan to use them to finish the ceiling with nails, drywall, etc. Are there any concerns with using PT instead of framing lumber? Can I still use normal fasteners and lightweight drywall? Thanks in advance.
Alexz2525 is offline   Reply With Quote
Old 09-05-2018, 11:00 AM   #2
retired framer
Rewards Points: 4,616
Re: PT Lumber Concerns for Finished Ceiling
One or two pieces get used in every house, I would not settle for a whole order screwed up. Your question about fasteners is enough for you to say this is not something you should not have to think about.
Old 09-05-2018, 11:09 AM   #3
If your using standard interior screws, the pt will corrode the screws. You'll need to use exterior grade hardware. The copper eats the zinc.
Deaknh is offline   Reply With Quote
Old 09-05-2018, 11:20 AM   #4
Rewards Points: 322
One common concern for me when it comes to pressure treated is the stuff I buy is usually super high moisture content and shrinks twist and does all kinds of crazy stuff as it dries.
I have seen it break screws. I can imagine what it could do to drywall nails/screws.
I would prefer installing something that is a little closer to its final moisture content.
rrmccabe is offline   Reply With Quote
Tags
ceiling , drywall , pressure treated wood
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
