Procedure To Balancing Torsion Springs - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By lothian
  • 1 Post By CrazyGuy
  • 3 Post By lothian
  • 1 Post By firehawkmph
Old 03-26-2018, 09:21 PM   #1
lothian's Avatar
Rewards Points: 24
Procedure to Balancing Torsion Springs
Q: What is the correct procedure to balance torsion springs AND counter-balance the weight of the door.
I'm spending waaaay too much time winding, unwinding, winding, unwinding the torsion springs on my 425lb 16' x 7' garage door. I can't keep the torque in balance between the springs.
I followed the demonstrations in various YouTube videos exactly: I tighten the set screws after I've cranked the springs to the set number of turns, then release the winding bar. But each time, the left-side of the door lifts up and jambs the bottom-right roller in its track. This happens every... single... time.
My intuition tells me I'm over-winding the springs. Fine. I unwind both springs then wind and tighten in 5 turn increments. Excruciating. When I approach the "set number of turns", I stop and check the weight of the door. It's still to heavy, so I add two more turns and check again. Still too heavy. So I add two more turns and... the left-side of the door lifts up and jambs the bottom-right roller in its track.
Interestingly, backing off the springs from the "set number of turns" does nothing to lower the left side of the door. I have to completely release all tension on both springs, then stand on the left-side door rib to bottom out the garage door.
What am I doing wrong?
lothian is offline   Reply With Quote
Old 03-26-2018, 09:25 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Procedure to Balancing Torsion Springs
Confirm that the door is level to the world before winding the springs.
Next time you release all the tension in the springs, check the cable lengths for each side.
Longer/shorter cable lengths will make the door act weird.
It might make a difference.
Plus, if you have two springs, make sure they both have the same number of winds in them when loaded.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-26-2018, 09:34 PM   #3
lothian's Avatar
Rewards Points: 24
The door is level when bottomed out.
I wind each spring identically.
Cables are both the same length.
Each time the "issue" occurs, the cable pops off the drum on the right side. I have the shaft secured with vice-grips (per videos) to prevent the shaft from turning while I wind the springs. I had a theory that the vice-grips slipped--all I can do is tighten them more. yet still the left side popped up.
Old 03-26-2018, 09:37 PM   #4
retired framer
Rewards Points: 6,098
Are the springs a matched set?
Old 03-26-2018, 09:39 PM   #5
lothian's Avatar
Rewards Points: 24
yup.
identical, 'cept for left/right windings.
Nealtw likes this.
Old 03-26-2018, 10:50 PM   #6
Rewards Points: 1,222
It's been a while since I've fought with garage doors, but a couple things come to mind. If these are old springs, could one be weaker. Maybe one is stronger, so don't adjust them exactly the same every time, see what happens. Second thing comes to mind, is all the tension off before you start, maybe one side is still under tension and the other is not when you begin.
Nealtw likes this.
The best advice is always given from some Crazy Guy on the Internet.
Right Wing= too closed minded to ever learn & grow
Left Wing= so opened minded all brains fell out
CrazyGuy is offline   Reply With Quote
Old 03-27-2018, 12:36 PM   #7
lothian's Avatar
Rewards Points: 24
Healed!
It seems the problem was with the locking pliers I used to hold the shaft--they were worn out. The pliers slipped just enough to allow slack in the cable on the side I had them clamped (the left side each time).
I purchased two shiny new 10" Vice-Grips! I chomped one on each side of the shaft, I finished the job in the 15mins it should have taken on the first attempt.
Oy. Sometimes it just takes walking away from a problem to see how simple its cause. Will the life lessons ever cease...
Old 03-29-2018, 09:05 AM   #8
firehawkmph's Avatar
Rewards Points: 2,546
Just an FYI,
Springs don't have to be wound exactly the same for a door to work properly. In some cases, two different weight springs will be used. When both springs are on the same shaft, the shaft doesnt know how much each spring has been wound individually. The total tension of both springs is all the shaft knows. Cable length as noted in the OP's posts is critical.
Mike Hawkins
iamrfixit likes this.
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
lothian (11-21-2019)
Old 03-29-2018, 01:21 PM   #9
Still learning every day!
F250's Avatar
Rewards Points: 848
Originally Posted by lothian View Post
.... Will the life lessons ever cease...
Get ready... NO, they never stop coming!
Glad you got it fixed.
F250 is offline   Reply With Quote
Garage Door Torsion Springs HAWKTX General DIY Discussions 12 09-12-2015 07:21 AM
Can you add torsion springs to a Progress P87 recessed light jillechie Electrical 2 06-21-2012 07:28 AM
Missing Halo Torsion Springs. ChuckJa Electrical 1 11-22-2011 07:03 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
