Preventing Rust And Corrosion - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-03-2019, 02:07 PM   #1
Rewards Points: 72
Preventing rust and corrosion
I have a lawn leaf sweeper, the kind you tow behind a sit down mower that i was planning to leave outside this winter. I don't have the garage or shed space to store it so was planning on just leaving it out in the elements under a tarp. Is there a spray that anyone can recommend to also help in preventing rust? something like corrosion x or WD40?
pats12 is offline   Reply With Quote
Old 10-03-2019, 02:36 PM   #2
Rewards Points: 3,582
Re: Preventing rust and corrosion
I'd probably consider a consider a can of Fluid Film unless something on the shelf seemed better. Readily available at many outlets.
Old 10-03-2019, 04:15 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,516
Paint the bare metal. Oil the moving parts generously.
Old 10-03-2019, 05:58 PM   #4
Property Mgt/Maint
Rewards Points: 7,586
Wouldn't recommend the standard WD40,
but their long term rust inhibitor https://www.amazon.com/WD-40-300038-...MCPZPKX9RE734W
[political signature removed]
Yodaman is offline   Reply With Quote
Old 10-03-2019, 10:27 PM   #5
Msradell's Avatar
Rewards Points: 978
I certainly wouldn't want to leave one outside, there's too much chance for it to prompt when you want to use it again. They are light enough to just hang on the wall. A couple of hooks up high on the wall and hang it from the handle. Been there done that many times and it works great!
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
