Pretty New House - Garage Man Door Air Gap? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-03-2019, 02:40 PM   #1
We moved into a brand new house at the end of 2016, and initially all the doors sealed pretty well. After a couple of years of daily traffic, the door that you walk through from the garage into the house (the one we use the most) has opened a gap between the sweep on the bottom of the door and the threshold. If a car is in the garage with the headlights on, you can clearly see the lights shining right through that gap across the floor.
What is the recommended way of sealing this gap back up? Install a new sweep? Add another one (on the back side of the door)? Do something to the threshold itself?
Any advice is welcome, and I'm happy to provide pictures later today if that will help.
Thanks!
AmplifyDIY is offline   Reply With Quote
Old 04-03-2019, 03:01 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 950
Re: Pretty New House - Garage Man Door Air Gap?
I'd be more concerned why the gap has opened up. Unles it's something really simple such a worn/damaged/missing sweep, it suggests structural settling or shifting. If it's not that much, check to see if the door has a sweep that is mounted with slotted screw holes that can be adjusted. Light leakage is a good indicator but fumes leakage is more of a concern.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 04-03-2019, 03:03 PM   #3
There is definitely evidence of settling elsewhere in the house (some small drywall cracks at corners, etc) but nothing more than a hairline yet. I'll look carefully at the sweep that is there now tonight after work.
Old 04-03-2019, 09:21 PM   #4
Is the sill adjustable?
paul100 is offline   Reply With Quote
Tags
air leak , door , gap
Garage door threshold puzzle? I'm eager for advice. JulianFix Concrete, Stone & Masonry 18 04-11-2018 11:04 AM
Attaching my deattached garage to my house. biddlecom Building & Construction 1 03-28-2016 02:12 PM
Fire break between attached garage and house PrecisionVision Building & Construction 11 04-04-2015 05:59 PM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 08:54 AM
Feed the new house from the garage? Details needed. JohnstownFlood Electrical 1 03-18-2011 08:21 PM
