Post Rot (pic) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 2 Post By chandler48
  • 1 Post By Bondo
  • 1 Post By Canarywood1
  • 2 Post By Windows on Wash
Old 03-30-2019, 12:21 PM   #1
RRH
Rewards Points: 1,394
Post Rot (pic)
Usually I can figure out / find what caused a problem.
But cant explain this. Is on a small rental Home I own.
7 year old Porch post made out pine 1 x 8 rotting. 1 x 8's were primed and painted. And a bottom spacer of composite decking was used so would not soak up any water.
Two other post on the porch, made the same look perfect.
Any Ideas?
RRH is offline   Reply With Quote
Old 03-30-2019, 12:49 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,532
Re: Post Rot (pic)
Wood sucks...literally...these days.
Old 03-30-2019, 12:54 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 1,336
Re: Post Rot (pic)
Have you checked the rainwater runoff on that corner during a rain? Does it fall over the gutters and down the post rather than toward the downspout?
Bondo and Nik333 like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-30-2019, 12:59 PM   #4
Re: Post Rot (pic)
We have seen them where they are actually full of water from the top side.
We usually drill small weepers at the bottom to allow them to drain and a couple of vents is never a bad idea.
Old 03-30-2019, 02:11 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 262
Re: Post Rot (pic)
Ayuh,.... That is a kinda funky roof line convergence in the area,....
From above, was My 1st thought,.....
Nik333 likes this.
Old 03-30-2019, 02:26 PM   #6
Rewards Points: 1,042
Re: Post Rot (pic)
Seal the end grain of your new one with paraffin top and bottom and your good to go.
Startingover likes this.
Canarywood1 is offline   Reply With Quote
Old 03-30-2019, 02:52 PM   #7
RRH
Re: Post Rot (pic)
Yes, plan on going over there tomorrow and check the roof and gutter out.
I remember a couple years ago. I did a small repair on the side that had they same problem. But assumed some water got in around the bolt holes where the railing attached. Still did not make since at the time.
So the side with the railings really failed first now that I think of it. Sooner than the front and outside that were more exposed to weather.
Been awhile and a chance I still had a 4 x 4 post inside. If so I will just patch a foot up with some 3/4" pvc that I buy in 4 x 8 sheets.
If not may need to redo the whole post.
Actually hope I find a water problem. At least I know why.
Old 03-30-2019, 10:06 PM   #8
Rewards Points: 18,382
Re: Post Rot (pic)
It's rotting because you did not have the post sitting on a post base.
https://www.strongtie.com/postbases_...bases/category
Old 03-31-2019, 12:09 AM   #9
RRH
Re: Post Rot (pic)
Sits on 3/4 composite which should serve the same purpose.
Old 03-31-2019, 12:43 AM   #10
Re: Post Rot (pic)
The inability of the base to weep can be problematic in that comparison.
joecaption and chandler48 like this.
Old 03-31-2019, 09:09 AM   #11
Re: Post Rot (pic)
Not even close, waters getting trapped between the post and the decking and being sucked up by capillary action.
It would be no different than the post sitting on concrete.
I'd be replacing the post and adding a post base, idealy then wrapping it with a post wrap and never have to deal with paining or rot again.
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 10:56 AM
Tiling vertical post kellyharris15 Flooring 12 02-22-2011 04:28 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
