Porch Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-23-2014, 07:28 AM   #1
Porch problem
Can anyone help
Recently an elderly relative had her porch double glazed by a housing association - new outer and inner doors plus windows
Now she finds it very hard to open and close the inner door when the outer door is closed,
Its not a problem if the outer porch door is left ajar, so its obviously an air pressure problem
Is there a venting system out there to solve this particular problem,
The company who fitted them don't seem to have a solution.
All suggestions appreciated
Cheers
John jm is offline   Reply With Quote
Old 09-23-2014, 07:49 AM   #2
Retired Moderator
Rewards Points: 7,174
Post a picture of the doors---something as simple as drilling a hole in the door might be all that is needed-----
Old 09-23-2014, 07:54 AM   #3
Rewards Points: 144
I there is a door sweep at the bottom you may be able to raise it to leave a slight air gap.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
oh'mike (09-23-2014)
Old 09-23-2014, 02:40 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,400
Can you post up a picture? There is usually a good bit of adjustment in most newer doors.
Front Porch - Repair or Completely Replace? DIYerIT Building & Construction 1 05-26-2011 01:58 AM
Problem - Concrete Porch Slope johnjsa Building & Construction 1 05-21-2009 12:03 PM
Dawn to Dusk Porch Light problem jaw444 Electrical 7 04-20-2009 04:14 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
