Pomp Water Out Of Crawlspace - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 06-26-2020, 11:01 AM   #1
Rewards Points: 94
Pomp water out of crawlspace
Hi,
If I drill holes around an empty paint bucket, dig a hole in the lowest spot in crawl space with wrap it around some filter fabric and then and put it there:
https://www.walmart.com/ip/Superior-...-Pump/15125714
Is this an OK way?
Any help would be greatly appreciated.
chikitin is offline   Reply With Quote
Old 06-26-2020, 11:20 AM   #2
retired framer
Rewards Points: 15,542
Re: Pomp water out of crawlspace
The pail may not be big enough and cause the pump to cycle more. But the pail is cheap and it is a start, sounds like a plan. Dig a whole a little bigger and back fill with gravel
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-26-2020, 04:03 PM   #3
Rewards Points: 94
Thank you. I will do that.
Old 06-27-2020, 09:50 AM   #4
Rewards Points: 4,440
If you have the room, perhaps you could dig the hole twice as deep, and use stacked buckets. (Knock the bottom of one bucket and put it on top of the other.)
Just noticed that you want to use an empty paint bucket. Just go get a 5-gal bucket from HD.
huesmann is offline   Reply With Quote
Old 06-28-2020, 06:02 PM   #5
Rewards Points: 94
I just did pomp all the water that was leaking from my flower beds to crawl space from two spots.
Now I am left with a dirty vapor barrier and damp soil on the ground of the crawlspace.
I have a ventilation fan and left other vents open. If I remove the vapor barrier, will the soil dry? It is going to rain for 7 days starting from Wednesday.
Old 06-28-2020, 06:07 PM   #6
retired framer
I think i would open up, roll it back or take it out and let the dirt dry. If you are still having problems with the rain you may have to get to a more serious fix.
figure 7-14
Old 06-28-2020, 06:27 PM   #7
Rewards Points: 94
I will see after 7 days of rain if nothing is in there. I will do that. Thank you for the feedback.
I guess my next step would be to hire someone to remediate the mold:
1. remove the fungus/mold
2. disinfect the wood
3. disinfect the wood
4. apply protectant
5. put back insulations.
6. apply efflorescence remover
7. put back the vapor barrier
Am I on the right path?
Old 06-28-2020, 06:50 PM   #8
retired framer
4. apply protectant
Yes, something like that. I would dry it out and make sure you have solved this problem. You might find companies that do all of this for you.
figure 7-14
Old 06-28-2020, 08:12 PM   #9
Rewards Points: 94
Thank you. I just don't trust the companies anymore. I hire a person and direct him to do the job for me. I inspect them before going to the next step.
Old 06-28-2020, 09:22 PM   #10
retired framer
Nothing wrong with that either.
chikitin likes this.
figure 7-14
Tags
crawl space , water drainage
