Is This Plywood Still Usable - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-01-2019, 11:53 AM   #1
Rewards Points: 422
Is this plywood still usable
Left this in the shed outside for a month. Its supposed to go under a heavy stand
Surface is rough/splintered now (humidity?). Is it going to crack/form dips/crumble apart? (layers dont look separated after cutting off an inch)
Is this plywood still usable-55776342_385222135592111_1185521075182632960_n.jpg
Is this plywood still usable-55865114_371475847035694_5634723172222763008_n.jpg
Doug Locke is offline   Reply With Quote
Old 04-01-2019, 01:20 PM   #2
Rewards Points: 7,569
Re: Is this plywood still usable
It's probably okay. Under a stand means what?
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 04-01-2019, 01:23 PM   #3
Rewards Points: 540
Looks fine. It doesn't look like exterior grade plywood so being in the shed can degrade it slowly from too high humidity and condensation.
carpdad is offline   Reply With Quote
Old 04-01-2019, 01:29 PM   #4
retired framer
Rewards Points: 6,028
If it a rough plywood it has exterior glue. If there is any moisture in the first layer I would not lay it directly on the floor for a few days, if that is the plan.
Do not use flat bottom gables with scissor trusses.
Old 04-01-2019, 05:38 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 224
Ayuh,.... If ya dry it out, it oughta stabilize, so long as ya keep it dry,....
as for the finish,..... Sand it again,...
Plywood over diagonal subfloor-installation details roobinsteen Tiling, ceramics, marble 12 08-29-2016 08:49 PM
Repairing Plywood Ceiling in Cold Room an318z34 Building & Construction 7 08-04-2016 09:08 PM
Combining Plywood over 2x4s mulvihwm Carpentry 1 09-14-2015 01:32 AM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
