Pilot Kicks Off When Fireplace Burner Kicks On - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-19-2017, 09:44 AM   #1
Rewards Points: 4
Pilot kicks off when fireplace burner kicks on
I recently installed a remote controlled gas valve in my fireplace. I can get the pilot to light, but as soon as the burner is turned on (with remote or control box) the pilot goes out. I have tried everything to get it to work but cannot. It seems that the gas to the pilot is turned off when the burner is turned on. I tested this by turning the pilot higher and then once the burner gas was turned on, i attempted to relight the pilot but no gas was coming out.
njatrle is offline   Reply With Quote
Old 05-19-2017, 10:47 AM   #2
Rewards Points: 898
Re: Pilot kicks off when fireplace burner kicks on
Check to be sure the control knob is set to the right position. Read the instructions.
BIG Johnson is offline   Reply With Quote
Old 05-19-2017, 11:03 AM   #3
Rewards Points: 4
Yep. Directions say control knob to pilot when lighting it and then to ON to run it. That's what I did.
Tags
fireplace repair , gas fireplace problem , pilot light
Gas (propane) Fireplace: Pilot OK, full flame goes out darthsmozers HVAC 4 11-23-2013 02:32 PM
Can a standing pilot use electronic ignition? richapple HVAC 20 11-26-2012 11:45 PM
Gas Water Heater w/ Electric ignition - no pilot Sparkus Plumbing 0 12-24-2011 05:10 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
