Paracord - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 4 Post By Bud9051
  • 3 Post By de-nagorg
  • 2 Post By Bondo
Old 05-13-2019, 03:27 PM   #1
Rewards Points: 154
Paracord
What do "you" do to keep paracord from unraveling? I have seen the heating tool they use at the hardware store but don't have access to one. I have tried using a lighter to heat it but haven't had much luck with getting a neat end that doesn't start to fray. So - what have you done that worked well? Thanks!
mrlabradog is offline   Reply With Quote
Old 05-13-2019, 04:59 PM   #2
Rewards Points: 8,082
Re: Paracord
Maybe my material is different but I get a wet rag ready and light the end of the rope. Then stroke it to wipe the melted end away from the rope and put out the flames. I prefer outside as it is safer.
If your rope will not melt another trick is to slide a piece of shrink tubing over the rope. Saturate the end with silicon caulking and then slide the shrink tubing out to be flush at the end. Use a hair dryer to shrink the tubing, clean off any extra and allow a day or two to fully cure.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
mrlabradog (05-13-2019)
Old 05-13-2019, 05:16 PM   #3
JUSTA MEMBER
Rewards Points: 1,520
Re: Paracord
Hand held propane torch. Mapp torch, and the wet rag trick should be adequate.
ED
lenaitch, Bud9051 and Johnny_inFL like this.
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 05-13-2019, 05:20 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 194
Re: Paracord
Ayuh,..... I burn the end of the cord with my lighter, 'n wipe it out/ off with a rag,....
de-nagorg and Bud9051 like this.
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Old 05-13-2019, 09:01 PM   #5
Rewards Points: 4,444
Re: Paracord
Lighter or a match is all I've ever needed to use.
stick\shift is offline   Reply With Quote
Old 05-13-2019, 09:32 PM   #6
Rewards Points: 154
Re: Paracord
I'll try it again. I've basically been using the lighter and wet rag method but either end up with a big glob on the end or it starts to fray in a week or two. The cord is on my pole trimmer so it gets dragged around a lot. Thanks!
Old 05-13-2019, 09:51 PM   #7
Rewards Points: 1,900
Re: Paracord
I've heard the suggestion that you can dip the end in that vinyl stuff meant for tool handles. Haven't tried it.
ChuckF. is offline   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
mrlabradog (05-14-2019)
