Older 3 Phase Motor Re-wire - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-15-2014, 06:16 PM   #1
Rewards Points: 4
Older 3 phase motor re-wire
I have an old lathe that was operating on 480 (?) 3 phase when pulled out. I have a phase converter to run it on 220 volt 3 phase. There is no motor plate, so I have no clue how to re-wire for low voltage. There are 12 terminals in the motor box. The terminals I can make out are labeled U, V, W, and X, Y, Z. I believe the top row is marked U1, V1, W1.I believe the lathe is German. Older 3 phase motor re-wire-lathe-motor.jpg The picture is how I recieved it running on high voltage. L1, L2, L3 enter on the bottom.
Any ideas ?
doctor_ratz is offline   Reply With Quote
Old 10-15-2014, 06:52 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,526
Is there any sort of name , make, model number on the motor?
Old 10-15-2014, 06:54 PM   #3
Rewards Points: 18,382
Are you in the US?
Do you even have 3 PH available where your trying to use this?
Trying to use this in the garage at your home?
Old 10-16-2014, 08:42 AM   #4
Rewards Points: 4
joed - Unfortunately, the motor has been painted over, and the area that the name plate was riveted to is no empty. My guess is that this is a 60's vintage machine, if that helps.
joecaption - I am in the US, and yes I have 3 phase power. I power all my tools from a sub panel connected to a rotary phase converter.
More info; the bottom row of terminals is where L1, L2, L3 are connected. The next row up are labeled U, V, W, second from the top is X, Y, Z, then the top row are U1, V1, W1.
As mentioned, this was hooked up and running when I bought it on 480.
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 04:15 PM
3 phase 6 wire motor stace Electrical 8 10-23-2011 11:53 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 01:51 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
