Old Under Slab Cast Iron Pipes - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-09-2015, 11:07 AM   #1
Rewards Points: 4
This is the 4th time in two years of ownership that my underslab cast iron pipes are backing up. We don't put anything other than TP in the drains we they still get backed up.
Along with snaking the drains, would anyone recommend having a video inspection done and relining the pipes or possibly replacing the pipes with PVC?
gspace7 is offline   Reply With Quote
Old 03-09-2015, 11:49 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 236
Ayuh,.... The video inspection Should atleast tell ya where, 'n what the actual Problem is,....
Bondo is online now   Reply With Quote
Old 03-09-2015, 12:08 PM   #3
Rewards Points: 4
Thanks Bondo, that's what I thought too.
Old 03-09-2015, 12:28 PM   #4
Rewards Points: 104
I bet it's roots.
five.five-six is offline   Reply With Quote
Old 03-11-2015, 07:38 PM   #5
Rewards Points: 4
Not roots, but tampons. Lovely wife cost me $185. But I did get a video inspection which revealed no roots, thank God.
However, the interior of the pipes are bumpy and causing things to hang up inside. Besides that a couple sections of pipe are holding water. The plumber said that was not good and probably due to settling.
Old 03-11-2015, 08:21 PM   #6
Rewards Points: 125
Yeah they can be nasty. If you have low spots collecting water etc. I would start a little savings account and put a few bucks in from each paycheck. Someday that pipe will need to be replaced.
jimn01 is offline   Reply With Quote
Removing/Replacing Cast Iron Vent Stack to Polyurethane-Inject Leaking Foundation Cra greenfrog5 Plumbing 2 12-05-2012 11:21 AM
Making new plumbing connect to old Cast Iron plumbing fallvitals Plumbing 12 10-13-2012 06:52 PM
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 01:37 AM
Cast iron vs mod/cons rickmay HVAC 46 10-21-2011 04:42 PM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 04:18 AM
