Odd Ceiling Fan Wiring... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-07-2017, 03:30 AM   #1
Rewards Points: 6
Odd ceiling fan wiring...
While replacing some old wall outlets, with new TR outlets, i came across a white wire connected to the hot side of a wall outlet... the black wire in this 14/2 pair is simply capped off in the receptacle box.
There are 3 pairs of 14/2 wires in this receptacle box total. see attachment...
In this particular 14/2 pair, the white wire is always hot and the black "capped" wire is only hot when the wall switch to the fan is turned "on".
The single pole wall switch that controls the fan has a single 14/2 pair in the receptacle box. The white wire in the wall switch receptacle box is connected to the top brass screw on the switch, the black wire is connected to the bottom brass screw on the switch, and the ground is connected to the ground screw.
The ceiling fan also has a single 14/2 pair in the box. the white is capped with the white from the fan, the black is capped with the black and blue of the fan, the ground is capped with the ground. see attachment...
My question is, why is there a white wire in a wall outlet that is always hot and somehow mixed in with the ceiling fan??
Removing this white "hot" wire from the outlet appears to kill all power to the switch and fan.
Is this normal/safe??
A little more information... my house was built in 1981 and i'm 90% sure the wiring is original. There was a reno job at some point during those years before i purchased the house.
I replaced a ceiling flush mount light with this ceiling fan years ago. It was a simple wiring job as the ceiling receptacle box had one 14/2 pair cable in it, nothing out of the ordinary there... although i wasn't aware of this particular wired outlet then.
dyarr is offline   Reply With Quote
Old 05-07-2017, 08:01 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 29,590
Re: Odd ceiling fan wiring...
Sounds like a switch loop that at one time controlled a receptacle and now controls the fan.
Old 05-07-2017, 02:21 PM   #3
Rewards Points: 6
I found the mystery junction box in the attic. I would post a pic but the forum won't let me until i get 10 reputation points....
so this is what is in the junction box: (14/2 wire from the wall receptacle box, 14/2 wire from the fan, 14/2 wire from the switch)
--all 3 black wires are capped together.
--the white wires from the wall and switch are capped together.
--the ground wires are all capped together WITH the WHITE wire of the fan...
Is it safe to leave it like this??? At the very least i think i will replace this old junction box with a newer box that has a cap/lid. This one was simply buried under the insulation with no cap/lid.
I am still 90% certain this is original wiring/configuration from when the house was built as it is all "type NM 14-2 with ground cirtex plastic 600 volts cerro (ul)". If it was changed as part of the reno i would think there would be some newer romex in the mix.
Old 05-07-2017, 03:17 PM   #4
Super Moderator
joed's Avatar
No it is not. White should not be connected to the ground.
Old 05-07-2017, 05:00 PM   #5
Rewards Points: 6
well, i was really hoping i wasn't going to have to change this but it looks like i will... to make this a "normal" ceiling fan switch, this is what i think i should do...
Re-purpose the 14/2 wire coming from the wall receptacle box (since it's already there) straight to the switch. Correcting the connection to the wall out (black to brass, white to silver, ground to ground etc.).
Then run the current 14/2 wire from the switch directly to the fan.
Since these wires are not long enough to make the runs i will have to junction them into their own separate 14/2 romex. I'll make these new junction boxes visible in the attic.
I really wish i could post another picture but it would essentially be this (http://www.do-it-yourself-help.com/w...eilingfan.html) diagram, scroll down to the "Source at the Switch", 2nd picture. As i said, my "source" wire would be the current "white/hot" 14/2 set as seen in my first in my original post. Although I will correct the connection to the outlet receptacle box (i.e. black to brass, white to silver, ground to ground etc.)
does that make sense?
Tags
ceiling fan , electrical wiring
Ceiling fan wiring mess mitchell1297 Electrical 2 05-16-2014 06:26 PM
Help with wiring Ceiling fan to dimmer to light fixture. how was it wired? RedDirtdog Electrical 3 04-22-2014 01:05 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 08:48 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
