Nice Location, Bad House, Help!!! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-09-2015, 02:39 AM   #1
Rewards Points: 2
Nice location, Bad house, Help!!!
I am thinking of buying a house built in the 1930's located in the northeast. It is a timber frame house with no insulation in the exterior walls and a MUD basement (a stream actually runs through it). Inspecting them from the basement, there doesn't appear to be any rot or mold in the 1st floor joists. But I am concerned when I do insulate the place. The basement would have drains installed and then a concrete floor. The foundation is poured concrete. The exterior walls would be insulated and a moisture barrier installed. The moisture content of the basement will change (probably put a dehumidifier in the basement). Concerned about doing all this work and then the 1st floor joists give out. Should I be concerned???
HPuck35 is offline   Reply With Quote
Old 08-09-2015, 07:57 AM   #2
Rewards Points: 536
1. You probably will have to get flood insurance, and that can be extra cost of tens of thousands.
2. May have harder time getting a mortgage, because of higher flood probabilities.
3. You may have to run double or more sump pumps (with battery backups) 24/7, which is not cheap, more maintenance and electric bills (big, hungry motors). And what do you do with all that water?
4. If you cap the basement, water probably will push its way through the concrete, which means you have to spend more money before you pour and for maintenance later.
Those are just 4 basic reasons to stay away, no matter how good the house or the location. Just find out how long it's been on the market. That should tell you why it is still available. I'm in NE NJ.
I was searching for a house past 6-7 months. The real estate listings and agents omit flood information. Always ask and if no definite answer, ask for flood map. Or go to the townhall and ask for the map.
Unless you know how to make the water go uphill, and I thought I had one, don't spend more than $5000 on a house with water problems.
carpdad is offline   Reply With Quote
Old 08-09-2015, 08:05 AM   #3
Retired Moderator
Rewards Points: 7,174
Oh, boy. Insulating is a wonderful thing--but it also holds moisture and can cause a wet house to rot.
I'd think twice about that property---get a basement pro in there to see what your options are---if you can't control the water---skip the house--or fill the basement and make a crawl space out of it.
mae-ling (08-09-2015)
Old 08-09-2015, 08:22 AM   #4
Rewards Points: 996
1930's AND a poured concrete foundation ?
AND a stream actually runs through it ? THAT i would like to see.
Fix'n it is offline   Reply With Quote
The Following 2 Users Say Thank You to Fix'n it For This Useful Post:
Cullen (08-10-2015), joecaption (10-23-2015)
Old 08-10-2015, 10:05 AM   #5
Rewards Points: 298
My house isn't that bad,but last year when a tree fell on it,I thought I would seriously be better off to bulldoze the house and buy a modular home. But,at 62 years old,I just didn't want to go into debt again.
Fixin up this old shack has been a losing battle!
flhtcu is offline   Reply With Quote
Old 08-10-2015, 12:28 PM   #6
Rewards Points: 379
Are you floor joists green or black or brown? I bet they are not green. If you insulate you might create condensation causing accelerated mold and rot of the floor joists and sub floor.
begal is offline   Reply With Quote
Old 10-23-2015, 01:28 PM   #7
I would suggest to have a home inspection that you are interested to purchase. Ask your Realtor or home loan specialist to recommend but make sure to check their experience when it comes to residential properties.
emortgage2015 is offline   Reply With Quote
Old 10-23-2015, 02:11 PM   #8
Rewards Points: 3,582
Well, at least it has running water, that is until it freezes.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Tom738 (10-23-2015)
Old 10-23-2015, 02:50 PM   #9
Rewards Points: 1,414
INSPECTION REPORT:
Well, we found a river...
Last edited by beenthere; 10-23-2015 at 02:56 PM. Reason: Removed company link in quote
Tom738 is offline   Reply With Quote
Old 10-23-2015, 03:41 PM   #10
Rewards Points: 5,348
Whatever the allure of the house might be, you lost me with the basement stream. I cannot see you controlling water in the basement.
Ron
B. Franklin 1759
Old 10-23-2015, 09:41 PM   #11
Rewards Points: 5,010
hydro-electric.??
ron45 is offline   Reply With Quote
Old 10-23-2015, 09:48 PM   #12
Rewards Points: 18,376
Most banks will not even give a loan on a house with standing water never mind a stream.
Cracked me up with Emortages advice, last thing I would do is ask a realitor for a suggestion on who to use to inspect a home, guess what, it's going to pass no matter how bad it is.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
changing location of electric service to the detached garage from the house. marlowc2 Electrical 3 06-13-2011 12:30 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Whole house water filter location Soloed Plumbing 2 02-04-2008 08:32 AM
